Results 1 to 8 of 8
Thread: I forgot the math for AFR in PE Table
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    It's been a while and I forgot how to check the numbers in the PE table to come up with the AFR.
    14.something devided or multiplied by a PE entry = AFR ratio.
    Is it like 14.62857 / 1.24414 = 11.75797739804202099442184963107
    Thanks, I'll write it down this time.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    ( devide )
    14.7 devided by PE table = your AFR command when you r in PE mode .
    thanks
    98 Z28
    stock ls1 engine,A4,Fast 90/90,SLP lid,Ms3 112LSA,LT Headers,TCI 3500stall,semens 60 inj,ASP under drive ,3.73 gear,11.82 1/4 .sold
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Go to the Engine | Fuel Control | General tab in your file and see what stoich is, they are not all set at 14.7.
    After that, decide what you want your PE ratio to be and divide the stoich number in your file by a number like 1.13, 1.14 etc to find your target.
    14.62/1.13=12.94
    14.62/1.17=12.5
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Jun 2009
    N. GA
    530
    Thanks Guys,
    Jun 2009
    MD
    36
    What all reasons would cause this formula to be off?
    For example my buddies car: 14.6 Stoich Commanded
    PE commanded: 1.3275
    Actual WOT AFR from dyno wideband = 11.5 all the way across
    But using the formula: 14.6 / 1.3275 = 11.0 AFR
    So what could cause the discrepancy?
    Advanced Tuner angrygoat's Avatar
    Oct 2008
    New Baltimore, MI
    358
    ve and/or MAF table is off
    Joe
    2006 M6 GTO
    APS TT
    10.76@131
    "The goal of tuning is for the tune to run well enough you dont need any corrective mechanisms"
    Tuner Chevy406's Avatar
    Nov 2007
    Huntsville, AL
    163
    Set your PE table to the desired AFR at WOT first. Then go back and re-tune your VE and MAF tables. I learned this the hard way also.
    Oct 2007
    983
    What Chevy406 said, plus the tailpipe wideband will always be off compared to one that is in the exhaust pipe or header where it should be.
    LS1 Tuning Guide
