Results 1 to 3 of 3
Thread: Do I have unstable WB or is this normal?
    Jun 2007
    Finland, Europe
    549
    I've always been wondering how stable the closed loop wideband readings should be. In my car the AFR gauge from Innovate seems to be hovering between low 14 and low 15 when the engine is in closed loop.
    So how it is, what is the normal range for example when cruising at 60 mph 6th gear in closed loop? Or in city driving?
    Here's a cold start log and some city driving in cold climate, with config and tune.
    Some info about the car/engine:
    - the car has 2 bar COS but there's no supercharger at the moment as in my home country there's very cold winter coming...
    - forged 427, 228/232 115 LSA cam, 245 cc heads, 9.8:1 compression, 60 lbs injectors (just ordered Greg's DVD by the way), boost-referenced fuel system with 58 psi base fuel pressure, Kooks 1 7/8 headers, etc.
    - Innovate wideband in the cross-section of Kooks (not in the headers itself)
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Can't see what your WB is doing without an equation. In CL your fueling will oscillate between 14's and 15's.
    Sulski Performance Tuning
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by WS6FirebirdTA00 View Post
    Sorry, I guess I should have included the info below?
    It shows how I'm using custom PID to get AFR into HPT via EGR (I think):
    (Innovate has been configured to have max 20 AFR and min 10 AFR and rest of the parameters according to "sound engineer" recommendations.)
    EDIT:
    Sorry this one:
    This is for the AFRerror%:
