Results 1 to 6 of 6
Thread: Fog Lights?
    Mar 2009
    Andover, MN
    446
    Fog Lights?
    Hey I have a 2002 Silverado, and since it was just a base model there isn't any foglights. I was going to put OEM foglights in it and the switch also, but I found that BCM file is different. I was wondering how do I go about changing this? Can I have someone try and segment swap it, or do I have to have the dealer do that. It lists the seperate file on the GM TIS site.
    Thanks,
    Eric
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Why would you need to do that? How do you want them to work? You should be able to wire it up off a parking light signal with a relay and have them work fine.
    Sulski Performance Tuning
    Mar 2009
    Andover, MN
    446
    Well thats plan B if I can't do it how GM intended to do it.
    Feb 2009
    1,931
    Had a friend do the exact same thing. He had the dealer flash the bcm, only way I know to do it.
    May 2008
    49
    Here's some good info. From what I gather, pre 03 needs to have the bcm reflashed. Here's a few threads to help. There's plenty more if you need more info.
    http://www.gmfullsize.com/forum/show...ghlight=lights
    http://www.performancetrucks.net/for...=fog+light+bcm
    Here's a thread incase you want to wire up different ways for your lights. Such as highs/lows on at the same time. Or every light you have on the front come on at the same time.
    98 TA
    06 1500hd cc 4x
    Mar 2009
    Andover, MN
    446
    thanks guys!!
