Need help.
I can't load tables from the HPTuners to the program. All 8 tables are opened, but I get a message: "Could not find one of the equation windows." It loooks like, the program can't found handles for MAP2 and RPM2 (I don't see it in the log window).
HPTuners v.2.23.3742.35115
tune - Hummer H3 MT 2008 all stock
I've also tried using a stock 2010 camaro file and attempted to load the equations and I have not been able to succesfully get them to copy over from HPT to the EQ program. I don't remember the error I get but maybe I'll edit this post later with the error message.
Does the command "Copy Equations From HPTuner" get constants from HPTuner and paste into the table "Equation Constants" only?
Then there is a way to solve my problem - copy the essential constants manually from HPtuner and paste to a .BEQ file in the appropriate format, and then load into the table "Equation Constants". Am I right?
Edit-view-advanced.
If I hear when will Dodge be ready one more time...I might do one of these
Awesome! Thanks!
I don't mind admitting that I am a newb....
I had found that my problem was that I renamed the VCM executable files on my machine because I had installed 2.22 and 2.23 on the same machine. I had renamed the VCM Editor.exe to VCM Editor 2.23.exe and the program didn't like that. So a little advice to anyone installing multiple versions of HPT on their machines, make sure the VCM executable file for the version that you intend to use for tuning virtual VE is left as the default HPT name of VCM Editor.exe. I have already informed the BluCat software writer of this finding so he is aware of it.
Are they all displayed in table only mode? It doesn't pickup the tables if they are in table+graph mode
Hi seems to work well but is there a format that suits the VE table layout in the Holden SS/HSV R8's and guessing would be the same in the pontiac G8's??
MAP(kpa)15,20,25,30,35,40,45,50,55,60,65,70,75,80, 85,90,95,100,105,110,115,120,125,130,135,140,145,1 50,155,160,165,170,175,180,185,190,195,200,205,210
And
Eng Speed(RPM)400,600,800,1000,1200,1400,1600,1800,200 0,2200,2400,2600,2800,3000,3200,3400,3600,3800,400 0,4200,4400,4600,4800,5000,5200,5400,5600,5800,600 0,6200,6400,6600,6800,7000,7200,7400,7600,7800,800 0
Appreciate it thanks!! Anthony.
You can modify the Table_Dim.txt file to make your own custom one. Open it in Notepad and copy 3 lines from a config and paste it in and rename it to what you want. Example:
I LS2 VE Format
400 800 1200 1600 2000 .....
15 20.625 26.25 31.875 37.5 ....
Copy the three lines from above that are in the file so you have the format of the data and just replace the numbers ONLY (there are tabs between the numbers so be careful) and then replace the "LS2 VE Format" with your custom name.
____________________________
2008 Convertible Corvette
Haltech CAI | Kooks Headers and X-pipe | 227/231 .613/.617 lift 115 LSA CAM | Tuned to death
I am doing everything listed above until I get to the part that says to open the histogram in the VE- AFR error (#10). I am assuming it wont show anything since this car has a virtual VE? Am I doing something wrong?
I skip #10 and it says the data in the clipboard did not match the highlighted size. I am assuming this is because the VE AFR histogram is not open?
Just in case you haven't found the answer open up your histogram and edit it to the same axis values listed on the VE table in the program. Worked for me. EDIT: LOL welcome to post #102 I guess this was discussed at length already.
ktoonsez,
Thanks that is kick assThat REALLY answered a lot of my questions on what to do with the impossible to understand VE tables in my G8 pcm. Should be a sticky IMO.
ktoonsez and everyone,
I have an 2008 LS3 car that was tuned speed density 2bar with EFI Live. The EQ table works and pulls the data into the LS2 2BAR VE format. However, when I look at the table it goes up to 255KPA or 2.5 BAR.
What i am looking for is confirmation of the RPM and MAP for the X and Y axis. I don't know what EFI live uses.
Unless the labels do not matter?
Thanks,
Adam
The Tuning School Graduate Class of 2009
Speed Density TT 97 Forged 347 Vette
Speed Density 2.5bar 07 Z06 Forged 427LSX TURBO
Both self tuned running on E85
TO ALL:
If you are having trouble getting all the equations you are doing 1 of 3 things.
1. You are not opening al the tables.
2. The tables are open in split mode or graph mode (need to be just in table mode)
3. You have renamed the HPTuner program on the hard drive (some have done this to hae 2 versions on the same machine)
This should help all of you having trouble.
