Page 13 of 17 FirstFirst ... 391011121314151617 LastLast
Results 241 to 260 of 334
Thread: EQ <> VE Version 3.5
  1. #241
    Jul 2011
    24
    Quote Originally Posted by SpecD View Post
    Hello. I have trouble VE Equation VE Table Generator-V3.5 & HPtuners with Copy Equations from HPtuner operation ( either Win 7, Win XP) see please screenshot
    Now i have Beta 2.23.743. Is it compatible with Generator?
    I havn't had open VCM Scanner with AFR Error log that time. Could it be main cause of trouble?
    I was going to try out the tool and found I get the same error. I read the small help file, but I don't see any tables in Engine/Airflow/Dynamic Airflow, only fields to change High RPM disable and re-enable. I also don't see a VE LoAltd table under Engine/Airflow/General. I did have the six tables open under Speed Density.
  2. #242
    Nov 2012
    6
    Anyone have this current version of the program that they can email or host somewhere? I cannot connect to the IP http://209.218.144.226 for the file EQ_ve3.zip
    Thanks!
  3. #243
    Sep 2011
    7
    Quote Originally Posted by kewl_blades View Post
    Thanks!
    I am having the same issue. Any help getting a copy of the program would be greatly appreciated.
  4. #244
    Jul 2007
    16
    MY link to the latest EQ <> VE Version 3.5 Program:
    https://rapidshare.com/files/116772128/EQ_VE3.zip
  5. #245
    Nov 2012
    6
    Thanks!!!
  6. #246
    Jan 2008
    28
    I've got a blown 2010 camaro that im trying to tune the vve on and I can't find a way to turn off the stft. no matter what I try it still does what it wants, does anybody have a way of turning them off? also is there a specific set of histogram parameters I am supposed to use for the EG VE program?
  7. #247
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Set O2 readiness to max temp as well as closed loop enable.
    http://www.dsxtuning.com
    Just say no to bull s***.
  8. #248
    Agreed with Dave, and you can also force closed loop off in the scanner in VCM controls, might slow scanning down a tad depending on your comp.
  9. #249
    Where is everyone downloading this tool from? The link posted above does not work
  10. #250
    anyone have a file of it that i can have?
  11. #251
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    767
    Is there a version 4 coming that is more accurate?.....
    2017 Toyota Kluger - 10.1" Android Custom Head Unit, Rockford Fosgate Speakers, 85kg Roof Racks. Prev: 2009 Cammed VE SS Sedan, DOD Delete, 210/218 550', RAMJet OTR, HiFlowCats, IQ System, Amp/Speakers.
  12. #252
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    I plan on slowing down next month and setting a few days aside for updating this...
  13. #253
    Put a price on it. You did a bloody good job of it. I've used it many times, your efforts should be remunerated IMO. I'd happily pay a reasonable price for it. I found out what being too generous gets you. BTW, what's wrong with it's accuracy?
  14. #254
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by SSUte01 View Post
    +1 to all of this.
    Not to be picky, but it would be nice to be able to define a table size from within the software. Not that it matters for me anymore, because all of my tables are already defined, but others struggle with the formatting from what I've seen.
  15. #255
    May 2009
    767
    Are you serious? Hmmm how to explain.
    Step 1. Generate your VE table using this software, save the VE table, generate the equation and import into HP Tuners.
    Step 2. Get data that you 'just' imported into HP tuners.... compare against your VE table you 'just generated' and look how far out it is.
    Hence the error % when generating the new data for HP tuners.
    It drives me totally crazy ...... If the software's error % was within a percent i wouldn't care but it's nowhere near accurate enough to be used mainstream in my opinion other then 'knowing' how to work around the issue and or work with it.
    I dont discredit the software, there i no other for us to use.... So it's as the saying goes 'better then nothing' and i appreciate the effort for what time and thought was put into it. All I would like to see is some refinement to it, getting it to solve it's accuracy issue.
    Personally I had hoped HP Tuners would of just 'bought' the software off Bluecat and implemented it into there software and refined it but that hasn't happened.
    Anyway.... So in response, do your homework and you'll see what i'm talking about.
    It just drives me nuts making a nice VE table only to generate the equation for it to be out a couple of % in important spots....
    arg I'll shut up
  16. #256
    Sep 2008
    1,668
    Quote Originally Posted by BigDaddyCool View Post
    arg I'll shut up
    I don't think you understand how math works. Because we're using equations to define 3D surfaces, you can't avoid exactly what you just described. In fact, I'd argue it's the same, or strikingly similar, with the software GM uses.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  17. #257
    Mar 2008
    St. Louis, MO
    4,859
    arg I'll shut up
    It is quite obvious that you don't understand the limitations of polynomial curve (and surface) fitting.
  18. #258
    +1 to all of this.
    Initially it took a bit to get the syntax right for customised tables that I use in the Scanner, but valid point.
    arg I'll shut up
    Yes, I'm quite serious. I am fully aware and understanding of the error and limitations of GM's equation for GMVE. Do you not think these errors don't exist on a conventional VE table of 'normal' resolution when you aren't dead on the defined RPM and MAP for the table. If you are that worried, why don't you use the custom OS with a definable 33 x 33 VE table with non-linear axes if you want. That should provide shitloads of resolution where you need it. That is my preference for SD only (although have utilised both).
    If you are still using GM's intended blend of MAF/SD, I still stand by the fact it is the best way to model airflow/airmass and gives the best results when time is taken to get it right (within a couple of %).
    I don't really appreciate the "do your homework" comment. I do my homework, far more than you perhaps realise I very inclined to help people, especially fellow Aussies, but somewhat misguided comments won't lend itself to help.
    Yes, I agree that evolution and refinement of a product is a good thing and always room for improvement, but knocking the accuracy of a product that someone has put considerable effort into and handed out on a platter for free, when the accuracy is limited by the mathematics not the producer makes you seem ungrateful.
  19. #259
    Sep 2008
    1,668
    Quote Originally Posted by Bluecat View Post
    I'd be happy to Pay Pal you some money in return for your time spent programming and debugging too.
  20. #260
    Aug 2006
    5BA8
    3,253
    Quote Originally Posted by MikeOD View Post
    I'm in on that.
    EFI specialist
    email=[email protected]
