PE is all MAF unless you have disabled the stock MAF and are running speed density. The STFTs are so far out of wack that the LTFT wont even stabilize. Get those MAF tables worked on quickly before you blow that thing up. The most knock is at part throttle it saw 20*of KR a few times. The car is going crazy lean according to the positive STFTs for the most part. 90% of the issues here will be solved by well constructed MAF tables.
Well you made it sound like you would have to rewrite the entire scanner program or something lol. A histo for AFR error has like two values in it.
RSG Offroad
Jeeps. Jeeps. And more Jeeps. Oh and Jeeps too.
^ nope, just delete the vcmsuite and then reopen the scanner and editor, then enter your application code and ur good
Caution:Slow Learner
In all honesty Andrew I would let Flit step up and fix his mistake thats on YOUR car. This is his issue as to why your car is sitting with this tune. Make him fix it.
Your making it sound like I havn't offered to finish the tune.
He's roughly in the middle of both yourself and I.
In all honesty, Andrew seems to be the type who wants to try and take matters into his own hands. The help will always be offered on my end, and yours considering your concern.
Last time I'm going to mention this, cause you seem to like to spread rumors. The night I tuned his car, he was not knocking FYI. What ever has happened since then I don't really know much about other than he's made a few changes to spark, and has been playing w/ cruising MAF.
You fail at reading, the reason for his knock in that log isnt my doing.
Oh no, of course not. Knock just magically appears
These are the results from your tune. Kinda hard to say it isn't your doing.
But if you want to keep telling yourself that its not your fault, So be it.
This isn't on my conscience. Whatever lets you sleep better at night.
Also, that second log is from the dyno day. To my understanding thats all you.
Don't know if you want to play the "but thats 4th gear" card. This is still no excuse.
This is the log from the Dyno day.
ouch that looks like another poorly tuned tvs car i've seen by an east coast tuner. yeek.
im glad my only knock was a one time 1 degree at 1056rpm
