Page 5 of 18 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 354
Thread: LNF STFT and LTFT Tuning
  1. #81
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,163
    yes
  2. #82
    Jul 2009
    Olmsted Falls, OH
    29
    For step one...when you create the custom PID...You don'thave to select a Sensor...just enter the Percent for units, Type in that coding at the bottom, and Name it?
    And then when I go into the Histograms and in the How to it says click Configure Histogram next to the number 12...I would assume that's the same as "Histogram Settings"...because I don't have an option for Configure Histogram...?
    OK so I finally got the Maf Corr 1-3 setup and then when I plugged it all into my car...All the Histograms except the Maf Corr ones started working and it just said this:
    "This Histogram is not supported with the current loaded parameters.
    If this Histogram references Tables, it is possible that the vehicle
    you are connected to does not support these Tables. It is also possible
    that the sensor required for the Table is not found in the loaded
    parameters.
    If this Histogram references Sensors, it is possible that the sensor
    required is not found in the loaded parameters.
    If this Histogram references PIDs, it is possible that the PID required
    You will find all of your loaded parameters located on your Table Display.
    To add more parameters, right click the table display and click insert.
    For example, if you have a histogram built that maps Timing Advance
    and you do not have Timing Advance inserted on your Table Display,
    the Histogram will not function."
    I'm assuming that means I need to add a parameter to the Table...but which ones? If that's even the problem?
    08 Cobalt SS - K&N drop in, Muffler Delete, ZZP 3" catless Downpipe, HPTuned
  3. #83
    Feb 2010
    The Desert
    480
    Out of curiosity, would dramatic swings in weather make a difference while dialing in the MAF? I would think so but I don't want to go making assumptions.
    My reasoning for asking this is I usually only have time to drive/log at night time (work is only 3-4 miles away, car barely warms up by the time I get in) and here in AZ, nights are pretty damned cold ATM (40-45 degrees). Am I wasting my time?
  4. #84
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Weather and humidity seem to affect it some. When the CAI filter gets damp in the rain on my CAI it shifts. I usually log the ride in and the ride home, compare the histos manually and make changes accordingly. If it's really whacked out a given day, I ignore it. Seems to take around 8-10 trips to settle after getting it close. I've only been trimming it once a week for a while now. So close that any changes I make come out the next time.
    Best I can get on the Hahn CAI is about a 2% drift with the weather.
  5. #85
    Feb 2010
    The Desert
    480
    Quote Originally Posted by Iam Broke View Post
    Thanks Iam Broke
    I noticed that while logging in some rain/rainy weather, my STFT were way out of whack and I was getting KR like no other as to where just a few days prior, there was very minimal, if any KR.
    So my understanding is that any attempts to correcting the MAF and STFT/LTFT is better than no attempt(s) at all?
  6. #86
    Jul 2009
    2,305
    Yep, it just takes a lot of time to get it right. If we could see more of the air & fueling tables than the few we have more of the mystery would go away.
  7. #87
    Feb 2010
    The Desert
    480
    C'mon BYT! Where's that re-write? I'm antsy as I'm having one hell of a time dialing in my MAF... With the stock filter/intake....
    TIA!
  8. #88
    Jul 2009
    Olmsted Falls, OH
    29
    Any updates?
  9. #89
    Jul 2009
    Olmsted Falls, OH
    29
    bump
  10. #90
    Jan 2010
    15
    +1 for an update! Can't wait to see the latest tuning tweaks. It's been taking forever to tune this Hahn
  11. #91
    Feb 2010
    The Desert
    480
    With Tom's help/guidance and a few pointers from Term and BYT, I've been fortunate enough (with the help of BYT's previous guide) to get my LTFTs to hover around -0.8 (usually -0.8 to 0.0) and my STFTs to quit wandering as much. Just takes a lot of time and patience guys, don't give up!
    I've also found that the car loves a whole lot more timing now too!
  12. #92
    Jul 2009
    2,305
    Ya, got my MAF trims in line, but mine still hates more than 12* timing WOT above 5k. Oh well. Glad it worked out for ya!
  13. #93
    Feb 2010
    The Desert
    480
    I wonder why though Tom? Anything you can think of at this point?
    Thanks again too! I'll have to do some WOT pulls, log it and shoot it all over to you and let you take a look
  14. #94
    Do want...
  15. #95
    Jul 2009
    2,305
    Quote Originally Posted by T-Man View Post
    Been fighting it since I started tuning it with Term's help since last July. Looked for any reasons suggested, including rubbing or hitting of any body parts, exhaust, ect.
    2 ranges colder plugs, no help. A ~97 octane blend of Leaded racegas fixed it but sadly, the 02 sensor wouldn't like that all the time. Pretty gray tailpipe for a week.
    Seafoamed it hoping carbon buildup from the original Trifecta tune caused it, no help.
    It's random on all 4 cyls. I see it most on #2 & 3, prob phantom but can't be sure. When it shows up on #1, I believe it though, don't want to eat the ring lands.
  16. #96
    Jan 2009
    Kansas City
    47
    I got the exact same issue. Mine is random too but mostly on #4. I almost never see it on #1. I tried to cycle the key several times a few different times to see if it made a difference but that seemed to have random results as well. I guess ive tried a lot of different things as far as trying to tune it out but to no avail. Less taking a ton of mid range timing out anyways.
  17. #97
    Feb 2010
    The Desert
    480
    Try a splash of Toluene
  18. #98
    Jul 2009
    2,305
    Drink it, smoke it, inhale it or put it in the tank?
  19. #99
    Jul 2009
    East Suckburg, PA
    1,163
    NICE lol
  20. #100
    Feb 2010
    The Desert
    480
    Hahaha
    $1 Bob!
