I've been searching and went through almost every maf thread. I am setting up my editor to start tuning my maf. I have the close loop enable-ect vs. iat set to 284*.
For Dynamic Airflow i've seen to change Steady State, hi/lo rpm thresh to 0. Also i've seen to set under Dynamic airflow, High rpm disable to 0. Wouldn't setting the high rpm disable to 0 be all that needs to be done? Or do both need to be done to run pure maf? I was thinking with high rpm disable at 0, it would disable the hi/lo thresh hold anyway.
So, i'm trying to run pure maf to tune. Any info i'm leaving out to get there would be appreciated!
