Results 1 to 8 of 8
Thread: Cam install...CEL's
    Feb 2008
    Pittsburgh PA
    112
    Cam install...CEL's
    Just installed a blower cam on a 2010 camaro with the tvs2300. Popped a P0340. This is the cam position sensor circuit if i remember correctly. Where is this located at and and any thoughts on why it is going off. If i find where its located at we can make sure it was hooked up properly and then continue on figuring out why its going off.
    2010 Camaro SS LS3 - Heads, Cam, Whipple 11psi 756whp 663wtq 93 and meth
    Its in the front cover off the engine .
    Feb 2007
    San Antonio, TX
    1,255
    P0340 OBD-II Trouble Code
    Technical Description
    Camshaft Position</font> Sensor Circuit Malfunction
    What does that mean?
    This indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM. Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it.
    Symptoms
    Symptoms can include:
    •Hard starting or no start
    •Rough running / misfiring
    •Loss of engine power
    Causes
    A code P0340 could mean one or more of the following has happened:
    •a wire or connector in the circuit could be grounded/shorted/broken
    •the camshaft position sensor may have failed
    •the PCM may have failed
    •there exists an open circuit
    •the crankshaft position sensor may have failed
    Possible Solutions
    With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
    •Visually inspect all the wiring and connectors in the circuit
    •Check for continuity in the circuit wiring
    •Check the operation (voltage) of the camshaft position sensor
    •Replace the camshaft position sensor as required
    •Check the crankshaft position circuit as well
    •Replace circuit wiring and/or connectors as required
    •Diagnose/replace the PCM as required
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Feb 2008
    Pittsburgh PA
    112
    well thanks for the step by step. will check it over later on.
    Feb 2008
    Pittsburgh PA
    112
    apparently the issue is with the cam gear itself. i need a stock ls2 three bolt cam gear not an ls1 cam gear.
    that's exactly what it is. cam gear has the "windows" for the sensor built into it, and your new gear likely does not. gear is less than $25 tho, just sucks to hafta go back in to change it....
    Jun 2014
    17
    But can you keep the VVT sensor with non VVT cover (shorter) or needs to put a non VVT sensor too?
    Advanced Tuner HartRod's Avatar
    Dec 2006
    Pensacola, FL
    489
    Quote Originally Posted by Gonzalo Bravo View Post
    Cam sensor needs to be changed to a non-VVT sensor.
    69 Suburban Bagged & Blown: http://67-72chevytrucks.com/vboard/s...d.php?t=200387
    68 Farm Truck build thread-LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
