Maybe I dont completely understand this but I wanted to ask anyway. This is stemming from a post I read about placement of the IAT sensor and I have seen some posts on here about tuning this table. If I understand correctly, this table is dependent on IAT sensor placement. Is that right? So the manufacturer has set up this table based on the location of the IAt sensor and the distance from the intake. It would seem to me that this table does not need changing unless you have changed your IAt location, i.e. moved it farther from the intake or TB. Would it also be true the closer the IAt is to the TB the less the bias range would be.
Does any of that make sense or am I missing the boat completely?
