Results 1 to 6 of 6
Thread: VCM Scanner and Credits Question
    Sep 2010
    Question VCM Scanner and Credits Question
    Does the VCM scanner work as a regular scan tool where I can use it with any car... or does it only activate for the car you have activated with the credits?
    Also does the VCM Scanner allow you to run some of the tests that the manufacturer scan tool can run? Like can you toggle the ABS system and run some of the tests?
    Advanced Tuner umrjmac's Avatar
    May 2010
    Lenexa, KS
    301
    You can scan vehicles without spending credits to license them. However, not all ODBII vehicles are supported (they're adding support for one of the other bus types soonish i think, which will give them broader support).
    Cycling ABS is not supported functionality.
    Kenne Bell Supercharged 2003 Corvette Z06
    Sep 2010
    Thumbs up
    Thank you.
    Oct 2010
    Temperature Edit/ Oxygen /speed Dis- Able
    Sir,
    My firend has an existing HP tuners suite with a basic credit (purchase direct from states
    In case we made to modify the Temperature or dis-able the oxygen sensor or open speed gm/ford vehicle do we have to had a credit licensed.
    Orthis credit licensed applied only once you made a pcm,vcm flash or programming.??? Well since they purchased this unit up to now they dont used it .
    Techno
    28,247
    If you want to modify the vehicles pcm you must license the file in question by using credits.
    Oct 2010
    Thanks bill
    By the way, Plan to purchase one hptuners suites GM base plus ford licenses
    for clarification,GM/ford support by this vehicle software, it means we can do modify open speed, dis-able oxygen sensor and temperature or vice versa. For your information this are only the thing we needed for the shop.
    Thanks again
