I am fighting a surging issue with a 2005 Corvette. This car was surging since it was put together with the 416 and TTI twin turbo kit with 60's. The cam is a 236/232 in a 116LSA and compression is 9:1. After it ran on a maf tune for a while from a previous tuner I tuned the car on a 2 bar SD via HPT. Since the 2 bar we've set the boost controler to 12psi, 15psi, and 19psi. The car has Motron 60's (tall). The car has meth that if I recall comes in around 7psi or so and a secondary fuel pump that comes in at 2psi and raises fuel pressure to 62psi. We've made 824 on boost alone and 943 on nitrous through a 4L65E with an unlocked 3400 stall. The car is driven a few times a week or more and probably gets 10,000 miles a year. I'm digging for the file right now and will post that in a minute.
On a side note I recently fixed an annoying P621 code the car was setting by removing the TR9 (installed when I put on the nitrous) plugs and putting back in TR6's. It turns out that TR7's and up are non-resistor plugs and will cause problems in 05'-08' Corvette's. Certainly will on a 2005.
