I logged a short run just a while ago. My AFR seems to be a little lean. Will you guys look at it and let me know what you think?
I added my current tune.
Bump for early risers.
2016 GMC Sierra 1500 6.2L
Your afr is fine, for N/A you want between 12.5 at 13.0. there was some detonation at frame 390. I would take your timing down 2 degrees.
Ian
2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
Ian,
Do you know why my TPS % maxes at 84% instead of 88%? I had the floor mat out of the car for that run just to see if it made a difference. It didn't.
That is normal some read 88 and some read 84.
Ian
