Results 1 to 3 of 3
Thread: how to populate boost ve table?
    When I convert to a 2 bar os (E40 05 gto) the boost ve table is all 0's. How can I populate this to start off tuning?
    Is there anyway to use the data in the main ve table to estimate the values that should be in the boost table?
    joe
    Jun 2009
    19
    Yeah there is a Flash tutorial in the Help section on this website and in the HPTuners software you installed on your computer.
    Here is the link. To get to here you go to Help->Getting Started Tab->Demos->Applying 2-Bar SD Enhancement.
    http://www.hptuners.com/help/demos/2%20bar%20sd.swf
    Basically what you do is copy the entire row in the 105 kpa section and paste it in the 210kpa section. Then you multiply the entire row in the 210 kpa section by a specific number (read the tutorial for this), and finally interpolate all the data between 105 - 210 kpa. If you can't figure it out on your own reply back with the attached hptuner file and I'll see if I can set it up for you.
    Quote Originally Posted by 01SDime View Post
    ok, i definitely missed that demo somehow.... thanks for the reply thats great....
