Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: drag car wont go over 5500 rpm
    a/f looks decent this was its first time out since the rebuilt turbo., here are some logs, the car wont go over 5500rpm, the injectors go flat, the rpms go flat, and the car doesnt accelerate much at all. here is a log, it felt like the transmission a th400 was slipping yet the trans temp is normal and it shifts firm. any help would be appreciated
    02 ss camaro, 370cu, th400, 88mm turbo, moser 9inch
    2002 Camaro SS, Twin S480s
    2006 Corvette C6, Twin Turbo
    1991 GMC Syclone, LS/AWD/AC
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    look for an inlet restriction to the turbo... what is boost doing?
    Steve Williams
    TunedbyFrost.com
    boost comes in to the set amount on the boost controller. then stays their, the rpms dont increase. the injecotr duty goes flat. i dont get it. do you see anything in the tune?
    Jan 2006
    Richmond VA
    1,950
    Everytime I have seen something similar it was not tune related
    Steve Williams
    TunedbyFrost.com
    transmission issue?
    Jan 2006
    Richmond VA
    1,950
    try uncovering the turbo inlet for a single pull and see what you get.
    Steve Williams
    TunedbyFrost.com
    intake off didne help, it oullsbetter with lower boost it seems, the injectors goflat which is weird.
    im lost please help, i did send the turbo out and precision rebuilt it. could it be a bad rebuuild?
    Jan 2006
    Richmond VA
    1,950
    well that's new info...
    So it worked fine before, it was rebuilt, and now it has done it since the rebuild?
    Steve Williams
    TunedbyFrost.com
    yes i sent it to precision. the turbo spins freely and seems to be working correctly. the turbo makes boost, even 20psi. i turn it down to 10 or so and it seems better. what could be wrong with the turbo?
    What do you have for valvesprings?
    07 ZO6- warhawk 427/APS TT/HPT 2.5bar
    [email protected]
    prc duals maybe 500 miles on them, little street mostly strip
    prc duals
    Jan 2008
    242
    Set Maximum Delta Airflow-PO101 Error to( 255 ), set DTCs PO101,PO102,PO103 to (2 N0 Mil Light),and PO.106 To (3 No Erro Reported..Then set Cla Airflow-P1514/P0068 Error to Max 4.10
    Quote Originally Posted by C5 2000 View Post
    u have seen this before? most people say its the converter or trans.
    Nov 2004
    231
    are you running an exhaust on the car?
    it might have a calapsed cat or muffler restricting the exhuast
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
    open 4inch down pipe
    Dec 2007
    248
    You had the pt88 on their before or is this a bigger than previous turbo? what about the plugs, did you change the gap in between?
    98 - z/28 Twin TC76's l forged 347 l boost cam l moser 9" l th400
    07.5 - GMC Sierra 2500HD D-Max daily
    09 - G8 GT wifes daily
    Mar 2009
    Andover, MN
    488
    Did ya try to run it with a charge pipe off? What about your fuel pump(s)?
    no i didnt take the charge pipe off, fuel pressure is good, twin intakes -8 feed. i had the 88mm before and just had it refreshed. plugs are autolite racing plugs. all looked ok. i sent the converter off today to have it refreshed. its under warantee so no biggie.
    man i have the same problem!!!! I cant seem to make power over 5500.... I thought it was the 4l60e so i switched to the th400, just about to get it finished up so well see if it helps!
    cjg454ss search my name and look for my thread... have you had yours on a dyno yet?
    5.3, 317 heads, ls6 intake, 02 ZO6 cam, hardened pushrods, PRC dual springs, FMIC, 15* timming, 18psi boost, th400 w/transbrake .... 600rwhp
