Results 1 to 11 of 11
Thread: 2bar 08 vette and reduced enguine power
    I have done all the patches and it stil wants to go in reduced engine power sometimes, any ideas
    2008/2010 LSX SHOOTOUT CHAMPION
    First 5th gen in the 9's
    TX mile LSX Record Holder
    GETTING IT DONE WORLD WIDE!!!
    Late Model Racecraft
    713-466-9900
    WWW.LATEMODELRACECRAFT.COM
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Any codes?
    No, but I have the p0101,106,and 121 min set to 492, and max set to 493, p0068, set to enable at 8192, and I have raised the max air flow v s rpm some as well. I have also halfed the ifr table, maf tables, and displacement because this is a turbo car, and has 96lb injectors
    713-466-9900
    Do you still have the maf enabled or are you running SD?
    With the SD C6Z's I've tuned I maxed the IFR and left all other tables stock then tuned with the VE table. (my car uses bosch high imp injectors that flow about 100lbs/hr at 58psi).
    Not sure if that would matter or not but I have not run into any reduced power modes.
    07 ZO6- warhawk 427/APS TT/HPT 2.5bar
    [email protected]
    SD, thanks i will try that
    713-466-9900
    It has a stock unported 90mm tb, it seems to do it mostly before start up.
    713-466-9900
    Tuner Street Legal's Avatar
    Mar 2007
    Houston, TX
    162
    Quote Originally Posted by Tunning @ LMR View Post
    with the key on engine off try to hit WOT does it do it ? if it does you could have something wrong with the tps or the throttle plate touches something
    i had a car with the same problem throttle plate was hitting the MAF on a procharged C6.
    Tuner adambrandt's Avatar
    Jul 2006
    BETHPAGE LI
    54
    i had this similar problem when I tuned my hummer for SD two years ago. Here was the origional thread. It turned out to be a vac leak that was causing the issue.
    http://www.hptuners.com/forum/showthread.php?t=7222
    The Tuning School Graduate Class of 2009
    Speed Density TT 97 Forged 347 Vette
    Speed Density 2.5bar 07 Z06 Forged 427LSX TURBO
    Both self tuned running on E85
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by INTMD8 View Post
    I have done this with Hi-Z 83s (same injector you are speaking of?) and had good results myself.
    Steve Williams
    TunedbyFrost.com
    I will also mention this car is a conversion from 6l80 to 4l80, and has stand alone for the transmission. I started with a 08 z06 file when i first started tuning it.
    713-466-9900
    It only seems to happen when you first start the car. I have checked and there is nothing touching the blade, maybe some can bus stuff I guess.
    713-466-9900
