I have a customers 2002 Camaro M6 that doesn't want to idle at all with the A/C on. It's a very modified stock cubed 5.7. The bottom end is forged, the heads are AFR, Fast 92/92 intake and TB setup, and factory GM 85mm MAF, with a FAST Toys CAI. I don't have the cam specs right in front of me, but it is on a 110 LSA.
I started logging, and was pretty shocked at what I seen. When turning on the A/C on vehicles, I usually never seen a change of more than 20 to 50 IAC counts, and 0.5 to 1.0 on the Idle Adapt (STIT), so you can imagine my surprise when I see such a massive change. When you turn his A/C on, the IAC counts go from approx. 70-100 to climbing rapidly, pegging at 310, and Idle Desired Airflow (IDA) jumps up from 7-10 range to 20-40, and Idle Adapt (STIT) jumps up to 20-40 along with IDA. Even if you manage to get the engine to idle at Commanded (900 to 1000 rpms for testing purposes), the trims and IAC stay pegged.
Obviously the A/C compressor is drawing a TON of torque from the engine. I wonder if it is potentially going south, or has gone south, even tho the system is blowing very cold air?
Possibly I'm missing something here. Please ask any questions that may help you in your thinking.
