Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 117
Thread: Ford Injector Calibration Data & Tuning Info
  1. #81
    Apr 2014
    Sweden
    8
    Haha there it was just in front of me, x3600, now it looks good. Thanks again Eric! I will never ask that question again
  2. #82
    Aug 2012
    Melbourne Australia
    344
    I am going to swap my injectors over to Bosch 52lb injectors (part number 0 280 158 117) which seem to be Ford motorsport part number M-9593-G302. I can easily convert the slopes and breakpoint values from 39.15 psi to 58.01 psi (2.7 -> 4 bar) but not the offset table. Does anyone know if there is a formula to convert the Ford injector data for battery offsets to run on a different pressure?
    Thanks in advance.
    Darryl.
  3. #83
    Jun 2005
    Southern FL
    2,044
    Quote Originally Posted by DarrylC View Post
    Darryl, the data you seek is in the below pdf link listed under "FNPW_OFFCOMP". Interpolate the values between 54.96 and 60.03 psi for 58.01 psi.
    https://www.fordracingparts.com/part...-9593-g302.pdf
    Further, careful converting your slopes, because, contrary to basic math, it won't be linear. Notice the slight difference in the multipliers at the various pressures for FNPW_LSCOMP and FNPW_HSCOMP? That's the beauty of a flow bench tester that Ford Racing has access to.
    Regards,
    James
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
  4. #84
    Aug 2012
    Melbourne Australia
    344
    James,
    Brilliant, thank you.
    I was already working from that sheet of data and assumed the other data was for return less fuel systems as we don't need if for our speed density system.
    And a great heads up on the multipliers. I always wondered why only some tables followed the math and not always perfectly.
    Again, thank you much appreciated.
    Darryl.
  5. #85
    Jun 2005
    Southern FL
    2,044
    You're most welcome! I was bored and played in Excel to derive you some data for 58.01 psi:
    Flow Rate Low: 69.7171429570824 (0.015913 * 1.216984418 * 3600)
    Flow Rate High: 59.6698951965732 (0.013497 * 1.228048521 * 3600)
    Breakpoint: 0.00001668566548 (0.0000144400 * 1.155517)
    PW Minimum: 0.711
    Offset vs. Voltage
    Code:
    6	6.166679688
    8	2.589009696
    10	1.70111214
    11	1.43438724
    12	1.234047204
    13	1.075197708
    14	0.935315316
    15	0.828625356
    Above data is based on the Ford Racing FNPW_OFFCOMP data:
    Code:
    PSI     Multiplier
    54.96	1.217962532
    58.01	1.185444
    60.03	1.163906356
  6. #86
    puting id 1000s in
    i can change the hi low flow rate
    but the break point is lbm/cyc but in hp its in kg
    and in the offset voltage i have to put an extra zero so what is on the injector dynamics paper work
    and the pw minimum needs anthour zero 0.000272
    do i need to change the flow rate vs pressure.
    if i put my sheet up can some one convert it so i can see it for my self.or tune with it all ready done
    thanks
  7. #87
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by RWTD View Post
    Code:
    PSI     Multiplier
    54.96	1.217962532
    58.01	1.185444
    60.03	1.163906356
    James,
    Thanks for providing this. Initially I was a bit concerned in that my values were very slightly different until I noticed your 60.03 value for OFFCOMP, my data came from the pdf (1.1638) yet you value is 1.16390... so I guess you got the values from something else.
    Regards,
    Darryl.
  8. #88
    any help trying to put my id1000s in to hp tuner for ford.looking for any help
    I think I may have it but has any one got any screen shots of what it should all look like
    thanks
  9. #89
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by fpv09 View Post
    thanks
    You can click the units and it will cycle through different ones. Set it to match and then enter the values.
    Eric Brooks
    HP Tuners, LLC
  10. #90
    Aug 2012
    Melbourne Australia
    344
    Regards,
    James
    Thank you James for your help, most informative.
    Once installed into my car the injector data was not the best as the idle fuel trims were hovering around +25% and the car was running leaner than requested. So I downloaded a GT500 tune and checked and the data Ford uses for it and it is different to the data for this injector from the data sheet. Once converted, the High slope from the GT500 was much closer and the breakpoint was similar but the other data is vastly different especially things like minimum pulse width (GT500 has .448 and the data sheet .711).
    Something is not quite correct. Either the injector is not what Ford uses on the GT500 (I have seen a picture of the injector and it is the same according to it) or Ford does not use its own data in the real world. All a bit confusing.
    Any ideas/thoughts would be greatly appreciated.
    Darryl.
  11. #91
    Aug 2012
    Melbourne Australia
    344
    After adjusting the scaling it turns out that the Bosch 0 280 158 117 injectors don't appear to be the G302. What I came up with was suspiciously close to the other 47lb injector (LU47). So I put the data in (the data sheet is not correct, especially around some of the 4 bar values that I needed but is easily fixed) and it is brilliant.
    All the fuel rims are around +/- 1-2% and we have good fuel supply from idle to redline
    So I would suggest you use this data
    https://www.fordracingparts.com/part...-9593-LU47.pdf
    for these injectors.
    Darryl.
  12. #92
    Jun 2013
    18
    The numbers on the PDFs need to be multiplied by 3600 to get #/hr values. They are in #/sec
    Thank you so much for this information
  13. #93
    Jun 2014
    8
    Looks like this thread gets resurrected every now and then... my turn! Would like to ask that you check the injector offset multiplier provided for the 13/14 GT500 injectors above. It looks strange in that the multiplier is lower at 60psi than the 50psi and 70psi values. Wondering if something was transposed or if these injectors just behave strangely with in that pressure range.
  14. #94
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by SaabV View Post
    SaabV, if you are referring to the LU47 data then yes the values are out and as stated particularly around the values the Ausy Fords need for 4 bar calculations. There is even incorrect data just have a look at the breakpoint comp at 55.95 psi it is lower than the previous value. Anyway I made some transpositions and calculations and came up with the attached spreadsheet. Having a look at it I think my offcomp at 65 psi is slightly different to the data sheet (1.2179 vs 1.2158).
    Woops there is a slight error in the calculation of the offset for 58psi (silly excel error I made). Updated values are:
    FNPW_OFFSET
    VBAT Offset 58.015
    6 6.596 7.6764248
    8 2.274 2.6464812
    10 1.483 1.7259154
    11 1.255 1.460569
    12 1.075 1.251085
    13 0.935 1.088153
    14 0.813 0.9461694
    15 0.719 0.8367722
    Sorry about that.
  15. #95
    Jun 2014
    8
    Thanks for the response Darryl. The injectors I was referring to are the Bosch 298 in the 13/14 GT500. Eric posted a screenshot with specs that look odd in the offset multiplier, implying that the injectors have less offset at 60psi than 50psi. I've never seen an injector behave that way so I was wondering if the 50/60psi lines were reversed of if they really have that odd behavior. The multiplier curve would be very smooth if not for the outlier at 50psi. Unfortunately, I don't have a stock 2013 GT500 file to verify against.
    2013 GT500 Injectors
  16. #96
    Oct 2007
    Crawfordville, FL
    2,412
    Stock GT500 file.
    Eric Brooks
    HP Tuners, LLC
  17. #97
    Jun 2014
    8
    Thank you.
  18. #98
    Aug 2012
    Melbourne Australia
    344
    When our export/import tune changes feature gets implemented, I will put together all of my injector values and make them available, so you can just click a few buttons and all the injector values are loaded in.
    That would be awesome
  19. #99
    Aug 2012
    Melbourne Australia
    344
    I am finding that the Ford injector data is not being used by Ford.
    The more standard tunes I look at the more I find the data is different. Take for example the GT500 tune that I downloaded from the repository (attached). These are supposed to be the 47lb G302 injectors but Ford does not use their own data. For example minimum pulse width in the tune is 0.488 yet the G302 data has 0.711, low slope is close but High Slope is not and many other differences such as Offset and slope modifiers.
    Anyone else finding this?
  20. #100
    Jul 2009
    326
    The test fluid can make a difference. What does it say on the calibration sheet? Heptane?
    Anyway this is common the SCT value files can be different to the stock files.
    Also in regards to the minimum pulsewidth, I'm pretty sure this value in the Ford Racing Summaries is based on a statistical value whereby the min pulsewidth is defined by the point where the actual delivered fuel mass varies from the commanded by greater than 5%.
    I wouldn't stress too much....you will find yourself adjust the slopes from those published in most cases.
