Results 1 to 10 of 10
Thread: 08 Gmc Turbo 5.7
    Tuner Schexnayder racing's Avatar
    Apr 2007
    south louisiana, arnaudville la.
    66
    08 Gmc Turbo 5.7
    i have a gmc, 5.7 built engine, turbo, intercooled etc. stock ecm. D.O.D. is turned off.. this thing pulls all timing out when it shifts 2nd gear???? down to 5 degrees, from 20.. even if i turn of knock retard.. still drops to 5 degrees.. 1st gear runs and pulls great, just when it shifts... its dead for a while.. and the timing is bouncing everywhere!! it is not detonating or knocking.. wtf..any help is appreciated.
    Jun 2005
    Southern FL
    2,044
    So what computer system is this? A Gen4 setup? Post up your tune, both modded one and the stock one.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Apr 2007
    66
    Apr 2007
    66
    anyone???
    Apr 2007
    66
    come on people, this thing is driving me nutz.. has anyone looked at the log??
    Jun 2005
    Southern FL
    2,044
    A few things:
    1: Copy the High Octane table to the HO (DOD) and LO (DOD) just to be safe.
    2: Under Engine, Torque Management, General, you need to disable "Tip-In Limiting, ETC limit". It's set to Enabled. If you can't see this, then you need the latest beta.
    3: I'd also zero out "Torque Reduction, Pattern Z" under Trans, Torque Management, as well as zero out "Torque Reduction, Downshift".
    4: Last, go to Engine, Fuel Control, Power Enrichment, and set the Power Enrichment Delay RPM to 0, Enable RPM to 0, and RPM Hyst. to 0. I'd also set the MAP setting back to the factory of 55 (you have it at 85). This will bypass the "PE Delay Timer", which HPT doesn't give you access to, and go right into PE when you meet the "PE Enable TPS" settings.
    5: If you don't have any cats, you need to zero out ALL the "Cat Lightoff" tables.
    Apr 2007
    66
    thanks, just e-mail them about latest version of beta... i will check these other things out, but it still has cats on it..
    Jun 2005
    Southern FL
    2,044
    K, good, please keep us updated.
    Apr 2007
    66
    update.... still nothing... tried everything, 1 at a time, no change... i feel like im
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    try logging:
    - ETC Source
    - Spark TqMgt Type
    - ETC TqMgt Type
