This winter i will be turboing my 05 GTO
At the moment i am running the 2 bar enhanced OS but still using the MAF and the 1 bar map.
It seems their are two direction to go and id like some opinions on what is better.
I'm going to start by running 2 57 trim turbos on the stock LS2 approx 620 RWHP but i want to have the tune "set-up" for a built block and upwards of 18 psi so only have to do this once.
should i go with the 2 bar map and use the MAF until i reach boost and then have the MAP sensor take over from there. I will have to use the AFR spark adder to adjust timing at different boost levels as i will reach the max Cylinder Airmass at a low boost setting.
or
Should i have the the IFR and MAF and other tables scalled in half to allow up to 1024 instead of 512 airmass. This will also give me a bigger range for spark control in boost but will this give me enough room for my goals of 18+ psi and not hit the 12K limit.
I would be using the 100mm MAF
Are their any cons to this method?
