I cannot download or upload any tunes to my car as I keep getting "Failed" when Preparing VCM. I also keep getting an ABS error whenever the failed comes up.
Any suggestions?
This is what I am seeing:
Any suggestions?
Battery or wiring issue is the most common reason for a bootloader time out error.
I have a brand new optima red top and no funky wiring.
Aftermarket stereo? Might need to pull the fuse or disconnect.
Steve
2007 GMC Canyon Z71-4x4 | 3.7 I5-Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | AMSoil fluids
Didn't work.
Weird. You try the easy stuff like rebooting? Also might want to close all your other programs. I have had the scanner cause the editor trouble when trying to load a tune with the scanner open.
Steve
Yea I only had up VCM Editor. Rebooted computer, tried like a hundred times.
The ABS fault is weird.
What worked for my is " Get VCM Suite info " (! bubble) first. Also I could not use an inverter with my laptop, would not connect at all.
I'm not going to argue the point any more than I already have, if you have an inverter remove it & try again.
This happens to me also, I have a brand new yellow top optima, I don't use any inverter what so ever. The only way its letting me reflash my ecu is by reading the entire vcm beforehand. Not per "session" either, EACH time I want to flash the ecu I have READ the entire vcm beforehand.
I figure if the battery or wiring was bad, it wouldn't let me read/flash at all?
04' Ion Redline - Intense Racing Stage 5 kit - Snow Performance Water/Meth kit - ZZP S3 H/E - Newly Built forged Internal Engine....Being KEPT alive this time via HPTUNERS.
Damn, stuck on the side road @ midnight because couldn't flash the pcm within the 10min battery life window the laptop had and car won't start, can someone PLEASE point me in a direction to fix this issue, this fuckin sucks
Reflash the pcm using the same file.
I have the same problem. It wont read or wright. I had no problem a month ago. I have rebooted, unhooked car battery and reconnected. I have tryed everything listed above and have refreshed my app. key any ideas??
6.2L L92 (525 HP) ARP Bolts, Comp Cam 224/230 cam and push rods, Patriot Gold Springs, E-Fans, 175 HP shot NOS, Percision 3200 mult-disc, and RPM Transmissions Lv 5.
Best E.T. So Far:
1.734 60 FT. Spinning off the line!!!
11.72 @ 116.09
- Good battery *check*
- Aftermarket H/U powered down *check*
- Looks around for any type of Inverter *check*
- Make sure all accessories are off *check*
-Try a high speed flash........
-Then try a low speed flash.......
-Restarts laptop tries again.......
Reads entire VCM, sits in hot car for 15mins b/c u dont wanna move......*voila!*
Attempts to flash the tune w/TINY tweaks you need to input from the logging....*voila!*
Now, more logging to do because MAF tuning just aint done on 1 log...*15 mins later*
Let's try to flash this thing again.............
Starts entire cycle all over again....WHHHHHHYYYY??? lol What kinda "wiring issue" do I need to look for? Why will it only let me flash the car AFTER I read ENTIRE.
Yes, sometime I AM able to quickly flash the car, ONCE IN a blue moon. YES, it will SOMETIMES work if I flash ENTIRE, still takes forever though. Sometimes after I try to write the entire tune then quickly enable high speed then try again, it WILL flash it right, SOMETIMES.
Could it be a software issue?
