Results 1 to 15 of 15
Thread: e38 differences?
    May 2007
    26
    e38 differences?
    Does anyone know the differences in the e38 pcms? i need a spare e38 for a 2010 camaro ss. i've been told it is different from earlier models. the new number is not available from gm yet. Any older one's work? any help would be appreciated.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,272
    Older ones won't work from what I've been told.
    Jun 2005
    Southern FL
    2,044
    It is my understanding and thinking that say an '06-'07 LS2 C6 and '06-09 Z06 could use the '09 LS3 pcm, provided they swap out the pedal assembly and TB.
    Why do this? Because for supercharged or turbocharged setups, the '09 LS3 E38 has at 15k Hz MAF table (versus 12.2k Hz limit), along with a 529.1 #/min MAF table airflow range (versus 67.7 #/min), AND it has a 127 #/hr IFR table range (versus 63.5 #/hr).
    I'm hoping to test this ability one day in the future.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Jun 2008
    NM
    52
    Quote Originally Posted by RWTD View Post
    I am certainly looking forward to seeing the results. This could be very beneficial to the FI folks.
    Cheers,
    Mike
    Dec 2007
    776
    Quote Originally Posted by blownsub View Post
    '09, at least on Corvette seems to be a considerably different piece of hardware even though it looks the same. '08 and earlier tunes in '09 ECM's, and vice versa, have been reported to kill the hardware due to memory allocation revisions. Or at least this was the case early in MY09.
    The '09 Vette LS3, 2010 Camaro and '09 G8's all run the same E38 hardware.
    '08 Vettes have a MAF calibration that goes to almost 1900 grams/sec at 15kHz (limit 4000 grams/sec which is almost 10lbs per sec of air), though the IFR is still at 8 grams/sec, which as RWTD points out is vastly improved in the '09 at 16 grams/sec. 2010 Camaro tunes have same limits as '09 Vette.
    Hope this helps!
    Nov 2005
    Houston, TX
    3,968
    Knock it off already, your giving my E40 an inferiority complex...At least there is a 2 bar OS for the E40, with fan table extension.
    Bill Winters
    Out of the LSx tuning game
    May 2007
    26
    Quote Originally Posted by LSX378 View Post
    Hope this helps!
    So you are saying an 09 vette ls3 ecm or an 09 g8 gt ecm will work even though they are different part numbers from the camaro? The part number for the camaro isn't even available from gm yet according to the dealer. part# is 12633238. Thanks for your help.
    Dec 2007
    776
    ACDelco shows the PN for Camaro/09 Vette and G8 as 12625455, and 08 as 12612384, 07 as 12597121. These are the service numbers which are printed on the ECM labels.
    Maybe GM has now brought a 2010 ECM under 12633238 out to confuse us yet again. Though it must be a very fresh running change. Does your HPT read your ECM OK and show the OS as 12633056?
    Only way to really tell which ECM you have is look at the base of the ECM installed in your Camaro. Though if they are basing the ECM PN on your VIN, no doubt it is accurate. GM has changed a few things recently like different oil pressure sensor, different orientation on ECM connectors. Proliferation gone wild .
    Apr 2003
    Almost 2000 feet.
    7,876
    Looks like the Hardware Engineers demonstrating "evidence of attendance" at GM... LOL
    Always Support Our Troops!
    Dec 2007
    776
    Quote Originally Posted by EC_Tune View Post
    Is that like "I revised the oil pressure sensor connector and saved a penny! Dont fire me I am doing something valuable" ?
    Apr 2003
    Almost 2000 feet.
    7,876
    Exactly. Evidence of attendance. Or maybe that new Mid-Speed Infotainment bus is causing issues.
    Advanced Tuner Braciole's Avatar
    May 2008
    New Jersey
    227
    whats the part # for the e38 for 06-07 corvette coupe?
    2007 C6 coupe LS3 416 6 speed mn Z51 3LT
    Vararam Snake charmer 160 Stat
    Kooks 1 7/8 headers with jet hot
    Fast 102 ported intake 102 TB RPM Level 5 T56
    MGW short throw ZIP 4.10 Severe Duty rear
    RPS TWIN DISC CARBON CLUTCH CCWs ele wp
    RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
    http://www.youtube.com/watch?v=PtOPy_lp2QY
    10.66 1.47 60ft 133+mph
    Tuner Doubledip's Avatar
    Apr 2007
    Sydney, Australia
    161
    service # 12597121
    Ultimate Conversion Wiring
    Aug 2011
    16
    Bringing this back from the dead.
    I am building an L92/4L80e combo from scratch. I have an '08 Silverado harness (V8/4spd). What would be the best ECM for my needs? Also which TCM? I am concerned to just get any of them and then have a limitation I could have avoided by getting the best one for my needs. I will be running boost if that helps.
    Aug 2011
    16
    Nobody? Looking to buy one pretty quickly here and help would be greatly appreciated. I did some research but coming up empty.
