Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Primary VE Tuning?
    Apr 2009
    Georgia
    148
    Primary VE Tuning?
    Im trying to tune my ve table by following the sd tuning guide. So I did a log today and my AFR error histogram shows -52 to around -57 Is that normal? I went ahead and posted a screen shot of what the ve table would look like if I multiply by % and smooth.
    Also attached my log, tune file doesn't want to load for some reason.
    Thanks Kyle
    06 Gto headers, catback, taylor plug wires
    First screen shot is changed and smoothed the second is factory.
    Apr 2009
    Georgia
    148
    Anybody? Im trying to tune this thing today
    Tuner Mez's Avatar
    Nov 2008
    Austin, Texas
    163
    Quote Originally Posted by kjhallex View Post
    Im trying to tune my ve table by following the sd tuning guide. So I did a log today and my AFR histogram shows -52 to around -57 Is that normal? I went ahead and posted a screen shot of what the ve table would look like if I multiply by % and smooth.
    Thanks Kyle
    No, definitely not normal.
    Apr 2009
    Georgia
    148
    Quote Originally Posted by Mez View Post
    Any suggestions on what im doing wrong?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Either your wideband or tune is off, but since you haven't posted your tune nobody can help you determine which.
    Apr 2009
    Georgia
    148
    http://www.ls1gto.com/forums/showthread.php?t=323658
    I cannot get my tune to upload for some reason heres a link to my post on the gto form which has my tune file.
    HP Tuners Support
    (foff667)
    28,268
    Check your dtc's to make sure your maf is failing, I believe its the p0101 code that must fail for you to drop into speed density mode.
    Apr 2009
    Georgia
    148
    Its showing a po103 I have a aem wideband and i set up a custom pid for it. And it seems to be really close to the gauge reading. other than bounceing around a little on hp tuners.
    HP Tuners Support
    (foff667)
    28,268
    I don't think p0103 always fails the maf, you can confirm this by changing some maf cells where you know maf would take over 100% in your calibration.
    IMO either your not in SD mode or your wideband is not reading correctly.
    If you believe the wideband info is good then its likely the other.
    Apr 2009
    Georgia
    148
    What do you mean by change maf cells?
    Sorry for all the questions and thank you for your time!
    HP Tuners Support
    (foff667)
    28,268
    Log maf(hz) to see what cells you are hitting in the maf table
    Similar to how you are hitting cells in the ve table your maf will still be getting a reading unless you unplugged it so you'll be able to see where you are hitting in the maf table.
    Apr 2009
    Georgia
    148
    Ok heres a log i just did with the MAF Hz in the pid. I'm trying to search on here and find out how I need to change the table and what table I need to change.
    Thank you!
    Nov 2005
    Houston, TX
    3,968
    OK, OK, slow down. First off, what config are you using? I'm able to take your first log and open it with the default imperial E40 LS2 config (which I'm not sure where I got, but have attached), load all data into histo 7 and I get negative teens, not 50's: See screenshot. Although the EIO PID says AEM Wideband Gauge and I'm not sure where thats coming from. In any case I think your config is the root of your problem. You said you set up a custom histogram for the AEM? Can you attach your config file as well as the VCM Scaner.cfg file?
    Bill must be slipping because as long as you see the P0103 DTC set then you've failed the MAF and are in VE/SD mode.
    Bill Winters
    Out of the LSx tuning game
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by 5_Liter_Eater View Post
    Wouldn't be the first time lol
    Apr 2009
    Georgia
    148
    I am now using this cfg. with help from another forum member I think I have found a problem with my laptop. Let me try to explain this as best as I can.
    When I right click in my histo gram and load all data I see -50's Someone else looked at my log on ls1gto and sees 14's and 5 liter also? So I install hp tuners on my desktop computer just to try it. And I see 14's in the AFR error histogram like everyone else.
    So I tried uninstalling hp tuners on my laptop and reinstalling and I still get the same thing. What am I doing wrong? Please someone help me. I posted a screen shot of what I am seeing the log file is to big to post.
    Thanks Kyle
    Apr 2009
    Georgia
    148
    Just sent an email to support... Hopefully I can figure something out.
    I think your logging "Commanded AFR High Res", when logging "Commanded AFR Low Res" always works better for me.
    Apr 2009
    Georgia
    148
    Quote Originally Posted by Proxses View Post
    Not trying to say your wrong by any means. But why would I be able to see my histograms incorrect. And everyone else sees the histograms diffenent than I do?
    Advanced Tuner TXZ0603's Avatar
    Dec 2007
    Houston, Tx
    375
    how many decimals are you putting in the log?
    2003 Z06
    Forged 347
    PTE Billet 67/65 Turbos
    FMIC / Dual 50mm Tial BOV's
    ID 1000 Injectors
    RSI Stage 4 Fuel System
    07 Z06 Cam
    Tripple Nozzle Meth
    ACT Twin disk clutch
    25# Boost
    Apr 2009
    Georgia
    148
    Quote Originally Posted by TXZ0603 View Post
    In the histogram configs?
