I just installed a kit on my solstice GXP today. It has a 3gph nozzle mounted on the cold side IC pipe about 12-16 inches before the Tmap (IAT2). I'm running 75% methanol/water.
I took it for a shakedown run with the onset at 10PSI claimed from the vendor. It seemed to pull hard, but my IAT2 was not impressively cooler, only a couple degrees cooler than ambient. In addition I was still logging some KR in boost at low RPM. After the run, i felt the IC pipe - it was VERY cold to the touch. So my qustion is why isn't the IAT2 showing the temperature drop when the meth injects? Ambient today = ~80*, lowest IAT2 = 74*. The pipe felt MUCH cooler than that, kind of like a nice cold beer out of the fridge.
I tried another run by turning down that boost onset, but that led to horrible misfire. I probably went too low and was getting quenching, which i understand is when the meth/water mixture extinguishes the flame in the combustion chamber. I hope that doesn't damage anything. Since i only have a screw for adjustment, ill have to wait until tomorrow to contact the vendor and figure out how to adjust it back to ~10PSI. Since lowering the boost onset isn't the answer, is it possible i need a larger nozzle to achieve full benefits?
