When tuning the VE tables on the L67, every guide I've seen says to make the PE Enable TPS HOT table 100 for all values. Why would you want to do this? I don't understand why you would do this because your AFR would be 14.7 for all kPa except under WOT. Is that not dangerous? Wouldn't you want to tune this table with a wideband and PE enabled?
