If my customer has installed the wrong cam gear and the car is triggering this code, am I beating a dead horse trying to get this car to start properly? It is hard starting sometimes, but runs fine once started. It is a boosted, cam car.
Yes, he needs to put the correct cam gear in the car. He has to use the one from the '06 up, not the '05.
Formerly known as RWTD
Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
He thinks the correct gear is in there but I am doubting that. Can installing the cam 2 degrees advanced trigger the code?
Any reason for installing it +2, or you're thinking that may have happened by accident?
He put the wrong cam gear in. He had taken some pictures before and after and you can see the difference. Kind of what I thought happened.
I'm having the same problem in a 2012 camaro that was installed a cam of bullit cams.
The problem can be placed in the wrong gear?
