I have a cam sensor nightmare on my 99 ta. swapped engines ,etc and got code p0342 first intermittent then more permanent. It comes back now instantly when you try to reset dtcs.
I swapped in a new cam sensor this spring . Still same problem.
I started checking wiring continuity and power seems good to the sensor connector.
I scanned for signal with my hptuners cam high low and low high PIDS.
No signal at all on either one.
Tach is dead as doornail another symptom and car is hard to start.
I did get it running nice for 15 minutes the other day not sure what was up but it didn't last.
Is there anyway to test signal of the cam sensor with just cranking the engine with no fuel or spark?
It is huge pain to test it running since cam sensor is behind intake and you have to remove intake to get to it..I doubt I have two dud cam sensors first one was working fine in pre swap motor and second was new gm pretty sure not jobber.
Can I ohm the sensor pins? Can I check just cranking engine?
Is there no way to know of these sensors are duds ?
If not sensor then next on list is going to check cam bolts to see if they have come loose. Then maybe swap out cams in case have bad reluctor.
Then only thing left is ecu or sell the car. Very frustrating.
