I recently built this car, it's a 243 headed car with a custom cam of mine. The heads are decked .018 which puts it roughly in the 11.3:1 compression range. Car is running TR6 plugs gapped @ .044.
I've got A/F adjusted in the 12.8-13.01 range on the STREET, and commanded timing of 27 degrees. However she will NOT give me anymore than 24. If I command a higher timing table, it'll knock.
Is this all she's got, or are there other areas I'm missing?
<---Rookie tuner
