How do you do it? Will calculating the percent change in cross sectional area and multiplying the table by that percent work?
Does anyone have a formula to get close when going from the stock intake piping to 3" or 4" piping?
2013 Cruze Eco - CAI, Catless DP, Catless MP, ZZP FMIC, Ported Intake Manifold, Mild tune (17psi), best 43.5mpg, 175ftlbs (pid)
2008 Solstice GXP - ZFR 6758, catless, AEM stage 1 water/methanol injection, Hahn Racecraft Intercooler, solo street race cat back, LE5 throttle body - 307whp on a dyno dynamics (stock turbo numbers), 100 octane EFR6758 numbers - 463whp/454wtq
THats how I do it. % change in cross section. Then fine tune using %error in afr, Always works.
Me love boost long time.
In the LNF all I do is use the ltft's as a global offset, then use the stft's to dial the AMf correction vs/load map.
All other Gm vehicles are WB less so I have to use % error. in combination with an external WB.
how do we tune the ltft in the lnf? and % error where is this screenshot perhaps?
try 1 percent thats what i got on my 3" cobalt pipe should be around same for you 1-2 %
My LTFTs are -5% across the board with my Dejon SRI, but mine has a 3.25" inlet not a 3". I just multiplied the MAF airflow vs frequency table by 1.05 all the way across. I hope that fixes it. I think my reasoning is correct: 5% more MAF flow for the same frequency should mean 5% less fuel added for the same MAF flow which should make for 0% LTFTs. Someone please correct me if I am wrong.
-5 LTFT means the PCM is removing 5% percent of fuel
Multiply by 0.95 to remove the fuel and you will have almost 0 LTFT
If the PCM is removing, multiply by 100-X%
If the PCM es adding, multiply by 100+X%
Make the same with the STFT values, it takes more time to adjust...
Terminator, look at averages, not max or min. Is not the same cold or hot engine, it has different STFT...
Thanks man still learning. I Have a histogram now of LTFT+ STFT as well as a STFT vs MAF frequency and STFT VS load and rpm and LTFT vs load and rpm. I have it better now and the car runs a ton better now but I have +7 STFTs at WOT so I need to make a slight adjustment to the high load areas. -1 LTFTs now instead of -7.
so maf correction table is for ltft? i know my stft were perfect when i adjusted the maf cal. table
I think MAF Calibration is to adjust for different intake diameter, MAF correction factor is to adjust fueling (LTFTs) after the correct calibtation is set.
So if you get an aftermarket intake with a LARGER diameter, will your MAF readings be artificially HIGHER or LOWER
I need help in this area too. I purchased an aftermarket intake and now after logging my LTFT's are in the negatives (-8 last), they used to be spot on at zero. I attached my log for reference. How exactly do I go about trying to correct this? Do I use the MAF correction table?
yay this is good info cause the port job and stage 2 on of a k custom k04 will def be freakin my ltfts and i didnt know what to change till now. all i had to do stock was move my stft and the ltft stayed 0 lol lucky me
thanks
