Trying to run the new E38 2 bar OS system. It looks like its a great way to go but I am running into a snag. When upgrading to the new OS, it now has a standard VE table, which is great. However, the VE table is all 0. You need to create your own VE table.
This is where I pooped a brick, for lack of a better expression! How can one calculate a decent VE base curve?
Secondly, on LS1 based PCMs, the VE curve is structured so that the numbers in the VE graph refer to a percentage of the motors VE, on a Yukon that we had in the yard has a range of 0-134%, for example. On the E38 OS its not a percentage but a number set ranging from 0-8192 (or something close to that). How does the percentage relate to the VE table, and in the E38 OS upgrade particularly, how does the 8192 relate?
I tried to use a VE table off of the same Denali (LQ4 6.0L) as a starting point. If I remember correctly, it was right around 40% at idle. When I put 40 into the E38 2bar OS it didn't do anything. When I calculated 40% of 8192 it idles and runs decently. So, can I just use 8192 as 100% and calculate for a base map? Or am I missing something?
If this is correct, and I can just calculate the number, why does the factory one go to 134% instead of just 100%?
Boy, it would be nice to get this car done. Any help would be greatly appreciated!!!!!
