Thread: Guys please help me out with this config!
    May 2009
    7
    I have my NGK wideband hooked up to my EIO and its reading the AFR correctly on the Main Table (The wideband is using the predefined PID for the NGK afx). I am logging Commanded AFR, and % afr error. The problem is that histograms #6 (wideband afr) and #7 (% afr error) are recording the wrong values.
    I suspect this has something to do with SENS.120 reporting incorrectly, because when I tell histogram #6 to reference the pid for the NGK wideband, the table will record the correct values. But, this doesn’t help me with histogram #7 because the PID cannot be changed. I don’t know what I changed to affect these two histograms but they were working fine a few days ago and now they are not.
    Would someone please take a look at this config file and data Log and help me figure out what is going wrong:
    Thanks in advance,
    Scott
    May 2009
    7
    Nevermind, Bill at Hptuners helped me fix this.
    Thanks Bill!
    Advanced Tuner angrygoat's Avatar
    Oct 2008
    New Baltimore, MI
    358
    what was the fix?
    Joe
    2006 M6 GTO
    APS TT
    10.76@131
    "The goal of tuning is for the tune to run well enough you dont need any corrective mechanisms"
    28,268
    In his case it was a custom pid skewing his values
