Results 1 to 9 of 9
Thread: No Full Throttle 1-2 Shift
    Dec 2008
    15
    On the street and even sometimes on the track I hit the rev limiter (7400) before I make the 1-2 shift which is set at 6700, once that happens the shift won't happen until a back off on the throttle. This also happens when I kick down from 2-1 anywhere below 45 MPH. Should I try a lower shift point, the wheels always spin with street tires on and it seems like the engine revs so fast that the trans doesn’t have time to react hence no shift. Or do I just need to resign myself to the fact that I need to keep my foot out of it below 45 MPH unless I’m at the track with the slicks on?
    94 Impala SS SS, F1 Procharged 409 (408.6) LQ9 15.5 PSI 670 to the wheels
    Tuner NOS500's Avatar
    Jun 2006
    Western Australia
    74
    Try lowering the shift speed not rpm at WOT in the 1-2 shift
    LS2 Alloy Block 402 - VORTECH V7 Gilmer driven 15 psi 937.3 rwhp street driven.
    Dec 2004
    Port St Lucie, FL
    115
    post the tune.
    Dec 2008
    15
    Here it is but you may not be able to open it I'm using the latest beta
    Dec 2004
    Port St Lucie, FL
    115
    can't open it.
    Feb 2007
    San Antonio, TX
    1,255
    Lower your trans. shift time to .100 across the board, and yes lower the shift RPM. You'll be surprised at what it actually will shift at despite you lowering it. I have a friends at 6350 and we kept hitting the rev limit at 6500rpm. We lowered to 6250 and the damn thing will actually hold to 6425rpm before finally completing shift. Lower yours in increments until you get it where it should be...
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Dec 2008
    15
    Thanks for the ideas, I'll work on it tomorrow and weather permitting at the track on Saturday.
    1994 Impala SS F1 ProCharged 409 669RWHP 10.88 @ 130
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Try logging trans output shaft rpm so you can calculate the trans mph which is used by the pcm to calculate the wot shift points.
    (60*Trans output shaft rpm)/trans output revs/mile(which is found in your editor file) is the calculation.
    For instance if your 2-3 wot shift mph is set for say 50mph and your transmission is getting a calculated mph of 48mph whereas the vehicle mph is 65mph the vehicle will not even attempt to shift until it reaches the transmissions calculated mph. I've seen it happen a few times and the easiest way to check things out are by double checking via a spreadsheet to make sure things are calculating correctly on both ends so you can at least rule that out as a factor.
    Dec 2008
    15
    I think we'll call this tune good, I lowered the 1-2 shift MPH to 20 and the RPM to 6200 and found the sweet spot, at least on slicks. Ran 10.80 @ 130 while spinning out of the hole and wiggling just before the 2-3 shift.
