I'm having trouble with the flash process on an 06 Vette, I'm fairly certain it has something to do with the ignition not being turned on correctly. The first time I try to flash I get the following error:
I'm then able to re-flash it, but it does a recovery. So my question is, how do I turn on the ignition properly (ie this car does not have an key type ignition switch, only the push button.) I believe the green circle has to light up, which it does after the first failed flash attempt. I know this may be very obvious, but if I'm missing something, if someone could point it out, it would be greatly appreciated.
- Chris
