Well I finally cammed my LS3, it isn't too big of a cam either, 230/234 114. When I first took it out after putting in the cam, on the bolt on tune none the less, it drove almost perfect. At light throttle right before no throttle there was some surgining/bucking.
After driving it a bit more the surging/bucking has become increasingly evident and I began to try to tune it out.
Refining the spark tables, coast down etc, do not seem to help much (they help, just not enough). Fueling seemed to be the thing that really and truly helped it. I programmed the 02 sensors to change the switch point to like 800mv at idle and low throttle instead of the 400. That seemed to help a bit, but I think I'm still getting some surging.
When rich, the car idles like it is stock. You would not be able to tell its cammed. However the surging is really starting to piss me off.
Is there anything I should look for in the tune? Or anything I should check at the car that would explain the surging?
