So I had my tune pretty much dead on on my stock 28lb injectors.
wot a/f 12.8-13.0 28* timing, no knock, fuel trims between -5% to 2%
I've now replaced them with the Cobra 39lb. obviously my fueling is way out of whack, still working on getting my fuels trims back in order.
but under wot my afr is lean at 13.5-13.7.
now in theory if rescale the injectors table correctly would my afr go back to the 12.8-13.1 range like it was? or am I over my head here an it would be easier to redo the PE table once my trims are back in check
