Results 1 to 5 of 5
Thread: PE rate and Delay arguement???
    Advanced Tuner Braciole's Avatar
    May 2008
    New Jersey
    227
    I bought the course The tuning school beginners course.
    One of the first things they tell you is to Change the delay to 0 and raise the enrichment rate per your situ, NOS, Bolton's, FI<etc..
    I see alot of my friends going fast with the Stock settings 1.000 pe rate and
    3000, 4000, and 5000 rpm delays???
    Am I missing something???????
    Please for the love of pete respond!!!
    Thanks in advance
    2007 C6 coupe LS3 416 6 speed mn Z51 3LT
    Vararam Snake charmer 160 Stat
    Kooks 1 7/8 headers with jet hot
    Fast 102 ported intake 102 TB RPM Level 5 T56
    MGW short throw ZIP 4.10 Severe Duty rear
    RPS TWIN DISC CARBON CLUTCH CCWs ele wp
    RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
    http://www.youtube.com/watch?v=PtOPy_lp2QY
    10.66 1.47 60ft 133+mph
    Apr 2008
    Buffalo,NY
    64
    Here is a bump for you Mike.
    |466rwhp & 411rwtq|Cartek 3X cam|Vig stall|Bolt ons|Stock 2.56 gears|
    |Stock compression|Cartek dyno tuned| HPTuners pro|
    Cam only
    60ft 1.53 - [email protected]
    60ft 1.56 - [email protected]
    http://s261.photobucket.com/albums/i...onverted-1.flv
    on cars the PE delay time is calibrated to zero, so regardless of what you set your delay RPM to there is no delay.
    enrichment rate sets how fast the commanded EQ ratio moves from the current EQ to the PE EQ ratio. ie. a value of 1 will move you instally to the PE ratio.
    I count sheep in hex...
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,025
    Like Chris said, they're apparently teaching you to mess with things that have no real effect upon how the vehicle operates.
    The values for enrichment rate are step size of phi (enrichment ratio) from stoich toward whatever your PE ratio target is. If you're going from 1.0 (stoich) up to 1.25 (about 11.7 AFR) any value of 0.25 or greater will just get there in a single step anyway, regardless of time. A value of 1.0 is pretty aggressive. Only the truck really use this to slow the enrichment during a highway emissions test (US06) to avoid dumping fuel too quick.
    Change it if you want, but it's usually just a placebo effect. You really need to have the injector values, MAF and VE right first before you can consistently tune this.
    May 2008
    New Jersey
    227
    Thanks for the replies guys, another waste of time, just started to think I was going somewhere with this
