Results 1 to 8 of 8
Thread: Cars commanded AFR going very rich at WOT when PE table commands a higher AFR?
    28,273
    If your PE table is commanding, for instance, 13.0:1 afr but in the scanner you see your commanded AFR dipping to 11.7:1 or somewhere thereof check your Cat over temp tables, if you still have COT enabled it will take over the commanded fueling if the requirements are met.
    In most LS1 calibrations the max enrichment rate is set to 1.25 from the factory
    Stoich/eq ratio=commanded afr
    14.7/1.25=11.7 commanded afr so this is the most common answer.
    Tuner Engine_HP's Avatar
    Apr 2008
    Middle East.
    117
    i remember having this problem after i replaced my o2`s
    Chevrolet LS1 Camaro 1999 M6
    My FQuick
    28,273
    Quote Originally Posted by Engine_HP View Post
    Theres no reason this would happen because of replacing your o2's.
    Apr 2008
    Middle East.
    117
    heres the thread: http://www.hptuners.com/forum/showthread.php?t=20272
    my afr wasn`t 11.7, it was 11.0X.
    i wonder why this happend
    My FQuick
    28,273
    The only log you posted shows 11.7:1 afr.
    Apr 2008
    Middle East.
    117
    then why do i see it 11.07. i shot u a pic.
    weired
    My FQuick
    Apr 2008
    Middle East.
    117
    bump
    My FQuick
    28,273
    because thats your widebands reading & has nothing to do with what this thread is regarding.
    This thread is talking about COMMANDED AFR not ACTUAL AFR.
