Results 1 to 1 of 1
Thread: **FREEZE ADAPTS and MAX PRESSURE**
    Apr 2008
    Buffalo,NY
    64
    Question **FREEZE ADAPTS and MAX PRESSURE**
    I was looking at the setting for the A6 trans and I seen under Transmission Diagnostics--->Invalid Torque Signal---> 4 settings and the two I have a question about are:
    Freeze Adapts(enable/disable). Whats described for the setting is: Invalid Tq - freeze adapts: freeze pressure adaps if invalid torque signal is detected.
    Max Pressure(enable/disable). What's described for the setting is:
    Invalid Tq - Max pressure: sets transmission full line pressure if invalid torque signal is detected.
    Ok, my question is for us guys with aftermarket high stall converters. Should we disable Freeze Adapts and Max Pressure under Transmission Diagnostics???
    Could these settings that are enabled hurt the A6 trans due to the fact of having an aftermarket stall converter?
    Could the aftermarket stall converter throw an invalid torque signal and then set the line pressure to max and burn up the tranny?
    Any help would be much apreciated!!!
    Thanks,
    Tony B.
    |466rwhp & 411rwtq|Cartek 3X cam|Vig stall|Bolt ons|Stock 2.56 gears|
    |Stock compression|Cartek dyno tuned| HPTuners pro|
    Cam only
    60ft 1.53 - [email protected]
    60ft 1.56 - [email protected]
    http://s261.photobucket.com/albums/i...onverted-1.flv
