Hey guys,can someone tell & help about what's going on with my tune please??Just started dialing VE table in 07 Escalade,so i installed WB sensors in B1S1 & B2S1,then modify tune file as follow:
Maf fail =0 hz.Disable COT,DFCO,LTFT,CAT test & post O2 test.
Open loop table & Eq ratio min, all set to 1.00,max CL ect temp,disable PE.
My intention was to dial it up to 4000 rpm only.I ended up with bank1 super super rich & bank 2 normal ??(Took off spark plugs,in bank1 all fouled ,bank2 all Ok)Any idea,your help is highly appreciated
Car mods:
Pro charger 8 psi,short tube HD,52lb inj,boost-a-pump
