Edit: Pulled file for now, working on one with better timing tables and no inconsistancies between high/low octane.
I have finally come up with a tune I like enough to post. I consider it better than the first tune I posted as it really responds better, especially for gear ranges/downshifts. I have also reduced throttle sensitivity a little to make it more smooth while at the same time greatly increased tip in response and feel.
If you don't look at the RPM's and gear shift indicator when in 4th, you might think it's in 3rd when you press the gas, the response is just that much better.
I do not know if it's faster overall but it's pretty close, just better driving.
This tune was made using the new beta 2.x with the added tables for accellerator limits, shift times, etc...so make sure you run the latest beta or newer version to get all the settings.
BTW: This tune increases your stock converters stall speed to 2200 RPM if your brakes can hold the tires from spinning (no problem with AWD)
