Advancing the exhaust cam would take high(er) cyl pressure and provide more impulse for the turbine to use.
To prevent a negative impact on power one would wand to delay the intake opening until the piston is on it;s way down. Preventing high TIP/end gas in the chamber from forcing intake runner reversion.
Id like to see Turbine inlet pressure on your setup.
Buy an Autozone oil pressure guage with large coil of copper tubing. drill & tap your elbow pre-turbine.
