ok, thanks. Just to be sure, just the prop gain map and leave the other prop gain values 'min on boost, max on boost etc as they are?
if you look at the pic I posted
The stuff that I changed are coloured pink, zero them
What sort of knock listening devices are people using? If any
Ive got a Smith's racing service Knock box. Its good but If I had my time again I would try a gizmo one, as they have a digital output apparantly so you can log it to your laptop. But hopfully the HP scanner will be upgraded shortly with those pids included and we can have them in a normal log-in that case the old Smiths Knock box will continue to do the job.
Alrighty cool, I've just been browsing the market and there's some pretty good stuff out there. I've just upgraded my LM-1 for an LM-2 and am looking to take the next step and get some sort of knock detection device, this is still only a hobby but if I'm gonna do it I might as well do it properly haha. I've looked into the knock box, the gizzmo, Phormula knock analyser pro and the plex knock monitor, which are all similar pricing around the $1k mark, but the last 3 give an output signal so like you suggest it can be hooked up to vcm scanner. I'm just loving all this new technology
Can anyone explain how this table works?
looking for some pointers.
i have just up load some tunes from a mates a car that has been tuned.
witch timing table would you use to tune at wot
spark borderline knock
mbt spark
as one of these table is still the same as the stand table
just asking to see as a few other tunes they have altered both tables
thanks
Bugsy,
All clear, Thank you for your help.. I will make the changes and get some good logs out of it.
A speedometer question, can anyone confirm when putting a larger profile tyre on a 19 inch wheel (35 to 40 series) on an FG falcon given there is no software control over the auto transmission does it auto scale the transmission change points when you change the settings for correct speedo reading or not.
That change is happening after the transmission (like diff gear changes) so it only throw's the speedo out, the transmission only see's changes when it's between the flywheel & speedo sensor!
Grant thanks for the response however my understanding is any change in the speed sensor signal is received by the PCM then processed to drive the speedo to determine at what speed the vehicle is travelling, this speed is then used to determine at what speed the gear change needs to occur as per the transmission tune program setting. So I suspect because the FG has no VCM suite transmission software control then yes the speedo can be adjusted to read correct but bringing the auto gear change to occur at the correct speed is not happening.
To further confirm this theory is a test on an LS1 tune file with a change to the tyre profile only, does change the kph speed settings in the transmission tune.
If this is the case then I have to go to a smaller wheel with a higher profile tyre rather than using a higher profile tyre on my existing wheels.
Can anyone confim that my assumption is correct or incorrect.
Speedo is driven by a speed signal from the ABS unit. Speed is derived from the abs tone rings on the rear wheels. Ford then uses the tire size/revs/km to determine vehicle speed. As Grant mentioned changing to a larger wheel won't effect the shift points and the are still essentially operating in a closed loop system
(when comparing shift points to engine rpm) however the shift points v actual vehicle speed (not speed indicated by the speedo) will be off.
I would suggest you have a read of this thread - http://www.hptuners.com/forum/showth...edo-Correction
I have done exactly as per described with my BF F6 when switching from 275/30/19's to 275/35/19's and they speed and shift points are correct.
if you do not disable the VID Block the car will continue to use the data stored there so changing the REVs/Km wont make any difference
04 Velocity MKII M6 & 06 BF F6 555 ZF6
Ive still been trying to flash a 02 ba turbo that has a new key and ignition. sent the file to support and emailed me one back to flash into the car do that but still doesn't work. I checked the dtc's and there is one theft detected engine immobilized. could that be the reason its not working? and it will need to be fixed by ford before i can flash it? i thought it was just a matter of turning off pats and it would be all good?
orangeute338 you should be able to use the file I sent you to flash your pcm, its the file you sent us with your vin thrown into it.
I have tried and can't get it to work. I thought would ask here too see if anyone else has any ideas also. One thing I just thought would not having the headlights hooked up be a problem?
We use plex and the knock box, the knock box is pretty damn good and shows up other devices well over the 1000 dollar mark.
The PLEX system is a great unit (visual as well as aural) but we do 3 cars a day and the setup time vs benefit of using it makes it a wasted purpose... for 90% of cars anyway.
Looks like this may be the reason I was having issues reading Ford's, strange it didn't have any issue's with any GM stuff.
I just need to find out what part it is & where to get it & should be back in action, guessing I had an over volt.
will the vcm2 ford programming tool work with this software
