Results 1 to 10 of 10
Thread: T42 update in next beta
    Guys,
    Some changes and new stuff for the T42 TCMs in the next beta.
    - change table references from Perf/Cruise to Pattern A/B
    - added new params to see what Pattern A/B are set to (eg. Cruise, Perf etc.)
    - added some more shift and TCC tables
    - changed shift pressure references from Normal/Perf to Pattern X/Y/Z, again along with what X/Y/Z are set to
    - added shift pressure temperature offsets
    - added desired shift time tables, offsets and multipliers
    - adapt pressure enable/disable switches for Pressure Pattern X/Y/Z
    - fixing some minor axes bugs, some axes are editable now
    Contact support@ if you want to try.
    Chris...
    I count sheep in hex...
    Mar 2007
    39
    has this been released? I requested the BETA and received it but don't see any new tables once installed. The version I have is 2_23_beta_11CK.msi
    2008 GMC Sierra RCSB 4.8L
    Sep 2007
    394
    Which vehicles does this apply to?
    pretty much anything that runs a 4spd auto with seperate TCM. eg. Gen4 V8
    Sep 2007
    394
    Quote Originally Posted by Chris@HPTuners View Post
    Bummer, it doesn't apply to me.
    May 2008
    Chicagoland
    22
    Quote Originally Posted by thesubfloor View Post
    I believe ours is the T43
    David - 07 C6 w/A6
    (GMautotech @ CorvetteForum)
    T43 already has all of this stuff and is laid out as Pattern A/B etc.
    Aug 2008
    28
    Quote Originally Posted by RCSBcolo View Post
    I too have the update, and cannot find any changes in the transmission section...I need to be able to adjust my desired shift times. Am I missing something? Thanks
    '08 TBSS - ProCharged | '09 G8 GT
    sounds like you need a later version of 2.23 please contact support
    Aug 2008
    28
    Received the newer 2.23 Beta and I now have the tables I've been waiting for...Thank you!
