I've learned that in order to get the MAF or VE tables AFR error closest to 0. Once I've choked the error to +/- 1 use multiply by 1/2% Seems to keep the error closer to 0, for me anyway
chris
chris
06 LQ4 2500HD CC LB 4wd 4.56, Dana 60,
17 3500HD 6.0 srw
GenIII Unlimited GM Full Size Truck/SUV
Serial cable to WiFi
why would anyone tuning with a wideband set the OLFA table to all 1.0's???
Maybe Bill@HpTuners can explain this...it did make it into their help menu as a user submitted walk thru. No wonder I'm always buggin' WS6FirebirdTA00 about his personal tuning guide! When is an understatement. Lol
Ditto. Couldn't have said it better myself. The real problem is as a noob not knowing what is bullshit and what is FACT.
Janky Monkey Tuning
Call or PM for tuning solutions.
Cell 210-954-4985
Wrench turning provided by 2 Tightwads Racing.
Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
Still lost? Consult a Pro!
www.thetuningschool.com
www.calibratedsuccess.com
www.tunedbyfrost.com
I want to sincerely thank all of you for your responses - you clarified several points for me, huge help.
I may have one or two follow-ups, but I believe you've put me on the right track. Thank you!
2011 C6 Z06 CE - all stock except Callaway Honker intake and Kooks LT headers
CFCO = Clutch Fuel cut off? I don't see it in my '98 calibration. Which models have it?
It's under DFCO's tab... something like enable clutch transition...
OK, I don't have it then...thanks.
Wow, this is not the way to do it. The OLFA and PE tables are Commanding Fuel Air tables, which means they dictate what the AFR should be. The VE table (and MAF, if used) let's the computer know how much air is entering the engine based on the axis sensors (VE: MAP x RPM, MAF: Hz), so that the ECM can calculate the correct pulse width to meet the OLFA and/or PE required AFR.
That other method is doable, but would require a lot of work to fine tune the AFR at given points of the power curve.
The quoted post above is one of the BS post to avoid, if you are a beginner and learning to tune.
I thought the PE to 1.00 was for VE tuning and not WOT...
2001 Z28 (Black-6 Speed converted to 4L60E) - Holley Hi-Ram LS3 Iron 6.0 bored/stroked 408 Forged Internals 11.4:1CR (anticipate 475+RWHP) Moser M9 35-spline Posi Strange center 3.00:1 gears - Best 1/4 Mile: 12.18 @ 113.15 (3360# race weight) when near stock --- No new times yet ---
BMR tubular front L/U a-arms and k-member. UMI Adj. T/A and adjustable rear LCA's, Spohn PHR and Dragbar. !Air!,!P/S!,!TCC/ABS!.
No folks...PE is never set to 1.0. The OLFA (Open Loop Fuel Adjustement) is set to 1.0 when tuning VE. The OLFA is used when you vehicle warming up to temp. and normally from the factory is set to a rich value as you vehicle warms up. You set OLFA to 1.0 across the board to command a target value. i.e. Value in OLFA = 1.0 / Stoich AFR 14.63 AFR. When you go WOT PE takes over which is then set to whatever you tell it...i.e. PE = Stoich AFR 14.63/ Value in EQ table 1.167= 12.5 AFR.
Janky Monkey Tuning
Cell 210-954-4985
IIRC and I may be wrong...
If your OLFA is richer than your PE commanded your computer will use the OLFA commanded fueling instead.
Like I said, I may be wrong, not sure if that's true anymore.
2012 Chevy Cruze A6 1LT RS
Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
there is no need for setting OLFA to anything weird for tuning. OLFA's effect will show up in AFR commanded, thus in AFR%error.
Janky Monkey Tuning
Cell 210-954-4985
True BUT if you leave in the stock values you will be shooting for an AFR value during warm up and regular driving (Your in forced open loop at this point) that is all over the place as engine temp. rises. Easier to hit a single target like OLFA = 1.0 = 14.63 stoich to tune your VE table in OL using a wideband.
Janky Monkey Tuning
Cell 210-954-4985
no, it's not easier to hit a single target if you understand the math behind AFR%Error. first of all, AFR shouldn't be a single target. secondly, you need these non-stoich values for cold engine operation. thirdly, you shouldn't be tuning on a cold engine.
So us newbies just need to throw the CPIG deal in the circular file?
Hmmmmmmmmm?
Jim
Talk About NEWBIES !!!
Just trying to learn. Please explain your reasoning? I understand AFR%Error to be nothing more than the difference between what I am commanding vs. actual AFR. Are you saying its easier to hit a constantly moving target AFR?
Realize hitting a single target AFR value when not in PE is ONLY used for VE tuning in OLSD. You still set everything BACK once complete. At this point you can either choose to stay OLSD or go tune your MAF to continue running hybrid (ve/maf) as from the factory. OR of coarse if your going to run MAF only you could do so but why waste time on VE tuning then...Lol
Janky Monkey Tuning
Cell 210-954-4985
