Ok here is my first question.
I have been doing a bunch of reading on the cobalt forum about making adjustments as far as when PE kicks in. In relation to kpa (as listed in hpt). I read that 100kpa = 0 atmospheric pressure. 0 boost, 0 vac. And to set your PE MAP Enable to 115 kpa, so PE kicks in at a low boost point.
But when I get on a conversion table I get this, 100 kilopascal = 0.986 923 169 31 atmosphere [standard]. Also when I type in 100kpa and what it equals in psi it comes up 100 kilopascal = 14.503 773 801 pound/square inch.
Now currently my PE Enable MAP is set to 55kpa which in atmospheric pressure, 55 kilopascal = 0.542 807 743 12 atmosphere [standard], Inch of mercury 55 kilopascal = 16.241 490 689 inch of mercury [0 °C] and psi 55 kilopascal = 7.977 075 590 4 pound/square inch.
So my question is can I set my PE Enable MAP to 115 kpa or is that wrong. And what would be a good PE Enable Map setting other than what it is set at now which is the stage 2 setting.
Man Im confused, should have paid more attention in math class 25 yrs ago
