LTFT Max Negative Value
In good engineering practice, what would be the most negative value LTFT one would run? i.e. is -10 to -4 acceptable?
((The issue, friend extremely anxious to get car back, after tuned to a very nice level of fuel and spark, LTFT's running -3 to 0, I added 10% fuel across the board knowing he is going to run the hell out of it. Twin turbos at 6 psi.))
thanks
tt
Did you tune WOT with a wideband? -3% LTFT is fine for cruise and idle.
Yes, tuned all via WB; VE, MAF, PE. Street tune only no dyno yet, that was my concern in case he happens to hit on some cell / area that I did not tweak. Otherwise the tune was at -3 to 0 on LTFT's and running a nice 11-12 AFR WOT. I added 10% to VE table, crap, not sure why now, guess to sleep better at nite.
thanks
tt
