Results 1 to 10 of 10
Thread: Powering wideband directly off the battery...
    Jul 2008
    Altanta, Ga
    35
    Does anyone see a problem with this? I have my wideband powered directly off the battery with a switch in-line that I use to turn the wideband on and off. I figured this would reduce any voltage step issues, but wanted to get everyone else's input.
    New - 08 C6 Z06 - intake only - 478whp/446wtq
    RIP- 08 C6 6spd - 480whp/441wtq - Bolt-ons/Cam
    Jan 2008
    Appleton, WI
    14
    I'd probably use a relay instead of a switch. If you forget to flip the switch you will ruin your sensor.
    '02 Impala L36 SC (ZZP SSM90 w/3.6" Pulley) WizAired CAI, N* Throttle Body, ZZP Yella Terra 1.95 Roller Rockers, Comp Cams 105# springs, Lucas 38# Flowmatched injectors, Milzy Motorsports Stage 2 heads milled .020, Ported LIM, SLP Headers, SLP cat, GMPP cat back, Thrasher Shift Kit
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Not sure that you would ruin the sensor unless you have a really crappy wideband but you might end up with a dead battery.
    Always Support Our Troops!
    Jan 2008
    Appleton, WI
    14
    Quote Originally Posted by EC_Tune View Post
    I'm just going by what it says in the manual that came with my NGK Powerdex AFX wideband kit:
    "The power terminal (RED wire) should have 11 to 28V DC attached (via a switch or relay) whenever the engine is running. If the sensor is not powered when the engine is running, sensor life will be shortened."
    So I guess it won't ruin it immediately but will shorten it's life. Maybe this isn't true for all sensors. The AFX kit is can use either the bosch or NTK sensors so I believe it is true for both of these sensors.
    Jul 2004
    1,579
    I use the AFX controller with an NTK sensor and I power it by directly off of the battery. While configuring the table, I may leave the wideband on for a while with the car off. I have not had a wideband fail by this use, but I now unplug it to spare the vehicle battery from the extra load. It is perfectly safe to wire the controller to the battery for tunign purposes. If it will be a permanent istanl, the you will need to wire it to an ignition source or have it powered off of the battery with a relay from an ignition source.
    Jul 2008
    Altanta, Ga
    35
    Thanks for the help guys. I have actually be running around this way for ~3 months. I mounted my switch right beside my ignition switch and its engrained in muscle memory to turn it on before driving and off after shutting the car down. I will eventually wire in a relay, but the autoparts only had your basic switches when I was installing it.
    I did it this way to avoid voltage variation so I could match the HPT interface and the wideband with the car in auxilary mode. I know when these cars are wired off of switched sources, the voltage varies from ign. to auxilary. I figured battery voltage would be constant regardless.
    Feb 2006
    central michigan
    349
    what that says is running without the heater will shorten life.it does not say that heating without running will shorten life.
    Jun 2008
    5
    another AFX question
    I have an AFX also. Since we are on the subject of instructions in the AFX manual. What about the part that says you should connect the signal ground (brown wire) to the same location as the main ground (2 black wires)? I was planning on running the 2 black wires to the battery (-). I would like to run the signal ground to the MPVI interface. How can I guarantee I wont end up with a voltage offset?
    Thanks!
    Jul 2008
    Altanta, Ga
    35
    I connected my signal ground to the MPVI EIO plug. I didn't remember reading that part of the manual.....maybe it was revised after I bought mine. Either way, it doesn't "appear" I am having any issues with the way I have it connected right now. The w/b has been very repeatable and with the help of a buddy, we picked up 10whp/8wtq across the board over my previous tune from a shop.
    Jun 2008
    5
    OK, cool. Thanks for the feedback.
    Here is where I read it. Page 10, rev6 of the manual, specifically point #2. But 1 and 3 are related.
    AFX Wiring Notes
    1. The AFX considers the point where the two BLACK wires connect to their
    ground as the 0 (zero) volt reference point.
    2. When utilizing the analog output feature of the AFX, always be sure to connect
    the system ground (two BLACK wires) to the same location as the analog
    SIGNAL GROUND (BROWN wire). The analog output wires (YELLOW,
    BROWN) may be lengthened as long as the appropriate gauge wire is used and
    the connection is solid.
    3. It is advised to connect the BLACK wires directly to battery ground or as close to
    this point as possible. Do not extend the two BLACK wires using a single wire or
    else this can cause a shift in the ground level of the analog output SIGNAL
    GROUND (BROWN wire) and any device linked to the analog output (data
    acquisition or engine controller) will receive an incorrect signal.
    I assume it would also be safe to sink the 2 black system grounds to the MPVI also? I forget what the absorption capacity of the MPVI is off the top of my head. But the AFX only uses 2amps during normal operation, 3.5amps during warmup. Maybe someone can confirm the capacity of the MPVI?
