Results 1 to 5 of 5
Thread: 2003 LB7 p0234 Overboost
    Jan 2007
    30
    LB7- Simple mods (Intake exhaust) now setting an overboost code.
    Wastegate working good, it's easy enough to turn off the code but but I see a parameter for overboost max error. I don't see a lookup table for boost.
    I could increase the overboost error parameter, or turn the code off. I hate to just turn the code off but it is a mechanical waste gate and working.
    Any suggestions. I'm thinking about just increasing the error until the code stops setting but any suggestions??
    Thanks,
    John
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,285
    Looks like most are just turning off the code, not sure of a better answer honestly.
    Jan 2007
    30
    Bill,
    Thanks for the reply. I think I am just going to turn the code off for now.
    I may experiment at a later date if I feel the need.
    John
    the desired boost tables are under Engine -> Torque Management -> Turbocharger
    I count sheep in hex...
    Jan 2007
    30
    That's what I am looking for. Thank you. It appears to be limited to an 8-bit number. Things make a little more sense now.
    Thanks,
    John-
