I got my car dyno tuned, results: 436rwhp/403ft-lb @ ~9psi.
Spec's:
D1SC procharger
3 core intercooler
FAST 57lb/hr @58psi fuel injectors
Now to the issue(s): After driving the car for a while i started feeling the brake different, whenever i approached to a light and applied the brakes, the pedal started vibrating. Then few minutes after i got the check engine light with the following codes:
P0171--Fuel Trim Lean Bank1
P0174--Fuel Trim Lean Bank2
P0556--Brake Booster Pressure Sensor Circuit Performance
Now to the facts, i know that P0556 code is due to a vacuum leak and the other two most people here associate them also to a vacuum leak. I've been trying to trace this down but i seem to get nowhere. I took all the vacuum hoses out and check for cracks, none, I tied all the hoses with zip ties and reset the codes. The brake pedal still feels weird and I'm still getting the codes. The only things i have not check are two check valve: one that is attached to the hose that goes from the front of the intake manifold (behind the throttle body) and the one attached to the brake booster. NOTE: Procharger makes you attach a vacuum block in from the back of the intake manifold to the check valve attached to the brake booster (this is done by cutting 3 1/2'' segment of the main brake booster vacuum hose and attaching the vacuum block) for the surge valve to get vacuum. In my opinion one can attach the vacuum block somewhere else in the manifold, perhaps from the front of the intake manifold.
I attached two log files so you guys can disseminate anything if possible...
I setup the new injector flow rate myself by just adding 1.3 to the IAT multiplier table. When i got to the dyno i had the P0174 code. My STFT were messed so the tuner adjusted all fuel trims. He setup the AFR about 11.5@5k rpm
Any help or feedback will be appreciated, thanks in advance,
ALEX
