Hi there
does any one have Config file for LM-2 and coustom PID and please help me with the offset .
Hi there
Would think it would be the same as the LM-1? There is a default setup for the LM-1 under the AUX insert list in the scanner.
Steve
2007 GMC Canyon Z71-4x4 | 3.7 I5-Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | AMSoil fluids
You are going to hook it up to the EIO interface? You derive the equation as shown here in post #5: http://www.hptuners.com/forum/showthread.php?t=9448. So you have to decide how to configure the LM-2's output(s). IE: 0-5V equates to 10-20 AFR. Take the voltage and AFR range and plug it into the user defined custom PID. Then if it's not reading the same as the gauge add or subtract from the offset (number that gets added).
Bill Winters
Out of the LSx tuning game
